Home > In Car Electronics (L322) > iPod Not Charging via iPod connection
bwelton
United Kingdom 2012 Range Rover Vogue SE TDV8 Zermatt Silver
Hi,
My iPod does not charge via the iPod interface on my MY11.5.
The iPod cable looks to be an original 8X2T-14588-AA.
I've tried it on a couple of different iPods, an iPhone 3G and also an iPhone 5C (by way of 30pin to Lightning connector).
Musics and track selection all works from the Steering Wheel, but just no charging. Any ideas why ?
Many thx
Post #274923 8th Aug 2014 7:21am
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Have you tried fully backing up then resetting the ipod back to factory settings on your PC via Itunes?...worth a try as its easy. GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #274950 8th Aug 2014 1:18pm
Martin
Site Admin
Does it not charge any of what you've tested?
Post #274951 8th Aug 2014 1:39pm
paulmoran2
sorry..missed that bit...must be a power supply issue then Embarassed GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #274952 8th Aug 2014 2:06pm
miggit
Hi, not sure if this will help, but I keep getting the not charging message on my Ipod, at first I thought that it was the Grom unit I had fitted to connect it the car. But its turned out to be the Ipod.
Apple installed some software, during an update, to encourage the use of Apple accessories and not third party. The net result is a warning when you connect the Ipod that your not charging, this is because the Ipod is not seeing the correct resistance on the data lines. But in most cases if you ignore the warning it will still charge the unit but not show the fact.
I have been using mine for a few days and it doesn't seam to have dropped in battery level despite telling me its not charging. If you have just done a system update on your Ipod this may be the cause of your worries, and if your lucky your Ipod will maintain its battery levels despite "not charging".
Post #274964 8th Aug 2014 3:33pm
