![]() | Home > Technical (L322) > Split turbo hose - TdV8 - can I drive ? |
ksskaret Member Since: 27 Oct 2013 Location: Tromsø Posts: 73 ![]() ![]() ![]() |
Just found out that I have a split turbo hose after receiving the fault message "limited performance" and the fatty ant into limp home mode. I am 600 km from home and not sure if I can find a replacement hose up in northern Norway.
Thanks Alistar |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8109 ![]() ![]() ![]() |
2000 rpm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8775 ![]() ![]() ![]() |
As long as its sealed up it should be fairly ok. Plenty of duct tape will help! There is nothing that can't be fixed with a hammer😜😜
Yes should be ok as said don't skimp on duck tape the more the better |
Did you get home OK ?
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
Me too Alistair, convinced myself it was the gearbox/torque converter as I was getting a judder at 1800rpm
I sealed the hose up with duct tape and it worked |
