![]() | Home > General > Buying a TDV8 what to look out for???? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8608 ![]() ![]() ![]() |
Not for me, unfortunately, my mate is after a 2007/8/9 TDV8, he's found one that's not far from me and I'll end up having a look for him...
crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698 ![]() ![]() |
I've just got rid of one that was purchased from a main dealer. It was checked and tripled checked but if you check my topic below you'll see that even with checks things can be wrong. I'd say set aside 3-5k a year for repairs or unexpected failures. I worked out to run mine fuel service finance etc it cost me around 1k a month. They're built in the uk so they're bound to be shall be say feature ridden!
£5k/ year to maintain one of these is a ridiculous amount of money and no matter how good a car, if you're in that territory with your own cash then either money is genuinely no object or you need to jump ship.
£855 selected warranty from the off.
ij.brooks Member Since: 12 Oct 2013 Location: Newcastle upon Tyne Posts: 30 ![]() ![]() ![]() |
Hi, bought my first FF in Feb 2014, 56 reg, some issues I found with mine after I had paid, were heated windscreen partially works (passenger side only), turbo hose split, wheel nuts were swollen, recent find of brake pipe corrosion, also if getting an 07 reg worth checking the age of the spare tyre, mine was brand new and never used but was aged 8 years which is unsafe to use so that needed changing, otherwise just the general checks like brake discs and pads, bodywork, parking sensors front and rear, wipers front, rear and washing function, especially the rear which I had to sort as gets blocked easily. check eletrics on seat, stearing wheel, mirrow folds, also heated seats and steering wheel. I would also try to get an air con service as part of the deal as I am unable to find when mine was last done, even though it is working fine. So far I have spent just over a £1000 on repairs alone in 6 months, not including 2 tyre relacements so have been a bit pricey but I love driving it, Hope this helps your friend. |
Thanks chaps, some useful info there.... Pete
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2280 ![]() ![]() ![]() |
I have had mine since November last year and done just over 17k miles and spent 2k in repairs being heated front seat fan replacement my choice as I like everything to work it was broken when bought replaced 2 tyres due to cuts picked up during floods service also all done at main dealer and last but not least new gearbox installed at cost of 54 quid under warranty mind you I did buy the LR select warranty for circa 900 quid
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
Since having mine from January the first fault I had was a dodgy lift pump in the tank which caused it to die doing 60mph on the Hogs Back. That was a long wait...
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
Other than routine servicing and consumables (tyres, pads, oil etc.), changing the auto box fluid and the air com condenser, mine has been absolutely fine over the 2 years/30k miles I've owned it |
Mine's petrol not desiesel but its an 08 and in two and a half years I have had to replace an O2 sensor and errr, thats it .
Robgosty Member Since: 20 Dec 2013 Location: Manchester Posts: 232 ![]() ![]() ![]() |
Think its the same as any other secondhand car, theres good uns and bad uns, hope mine is a good un (tpuch wood) |
BigJon Member Since: 05 Apr 2013 Location: Adelaide - Lower Mitcham Posts: 14 ![]() ![]() ![]() |
I know the conditions in Australia are different to the UK, but some of your yearly expenses seem huge.
Thanks for all the info chaps, have now found him a beautiful RR in top condition from a member on here... Pete
