![]() | Home > Technical (L322) > L322 - 2 electrical problems - related?? |
tymh Member Since: 21 Apr 2014 Location: Garstang Posts: 312 ![]() ![]() ![]() |
Hi
Genius!
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
Pulling the fuse for the air suspension is the same as disconnecting the battery. Steering lock to lock is the standard solution for resetting the steering sensor after a battery disconnection. An out of position steering sensor inhibits the air suspension.
Others have also reported problems with the wiring running to the door becoming corroded (mainly left hand side though). Worth checking the wires back in the A post area. .
Just a thought, does the central locking work using the key in the drivers door? |
No. It just locks the driver's door. The central locking locks all the other doors... Tym
Yup! That one's stored safely! ![]() (current) L322 3.6 TDV8 Vogue 2008 Tonga Green (previous) L322 4.4 LPG Vogue SE 2003 If it sticks, force it. If it breaks, it needs replacing anyway. |
SOLVED IT!!!
Ooops |
We've all been there |
