Home > Technical (L322) > 2007 TDV8 instrument cluster fault and heavy steering
-KATE-
2007 Range Rover Vogue SE TDV8 Java Black
Hi guys,
I'm a newbie so hopefully I'm posting this in the right place.
I'm having a few problems with my 2007 TDV8 Vogue SE, on start up it's like my instrument cluster drops out, when the key is in the ignition all the dials move as they should do then when you start the car up the dials all drop like they lose power then a few seconds later they jump back to where they should be, it only does this on start up not while driving. (I have a video of it doing this)
Second problem is heavier than normal steering, I've checked fluid levels, changed the servotronic valve still the same, when the BCU is un plugged and plugged back in I get light steering for around 3 mins then it goes heavy again, have also tried a new BCU and that made no difference.
Had the car checked for codes and there's lots of codes regarding can bus faults and Lost Communication With Instrument Cluster Control Module.
Any help on this matter would be much appreciated
Kate
Post #275487 12th Aug 2014 4:00pm
Dijit
Scotland 2007 Range Rover Vogue TDV8 Java Black
Hi Kate,
Did you ever get to the bottom of this?
Thanks Rehab is for quitters!!!
RR 2007 3.6 TDV8 Java Black *
RR 2007 3.6 TDV8 Zermatt silver *
RR 2000 P38 4.6 Met red *
Mercedes 300TE 4-Matic *
Jaguar 420 (1969) *
Nissan 300Z
Citroen XM 2.5TD X 6
Bentley Continental R
Hydrocon Highlander
Hydrocon Hamilton
Hydrocon Huntly
Am told the ones with a * are to be offered for sale! 😳
Departed
LR 1992 110 2.5TD
RR 2000 Holland & Holland 4.6 LPG
RR 4.2 Supercharged with LPG, Vogue SE 2007 Buckingham Blue
RR 2002 4.4 V8 Zambesi Silver
Post #278147 30th Aug 2014 10:46am
-KATE-
I did,
Instrument cluster drop out was due to battery, it had an underpowered battery fitted to and was only working to 75% capacity when load tested so new more powerful battery fitted and that fixed that problem.
As for the heavy steering the BCU had been programmed by the autologic, and when reprogrammed by the land rover dealer tool (ids) it has worked fine ever since.
Kate
Post #278160 30th Aug 2014 11:50am
Dijit
Thanks Kate. Long may it remain working! Thumbs Up Rehab is for quitters!!!
Jaguar 420 (1969) *
Nissan 300Z
Hydrocon Highlander
Hydrocon Hamilton
Hydrocon Huntly
Departed
LR 1992 110 2.5TD
Post #278163 30th Aug 2014 12:02pm
