![]() | Home > Technical (L322) > No Parking Sensors |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
Any use??
Shandonman Member Since: 02 Dec 2013 Location: Argyll Posts: 90 ![]() ![]() ![]() |
Thanks but it doesn't cover my problem.
Still no joy
No ticking at all ? could well be a chafed wire in the bumper , quite common . 2008 MY Supercharged
Do you have a tow bar fitted? If so, and its OE, plug in a trailer board which will deactivate the rears and show you if the fronts work without issue |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3957 ![]() ![]() ![]() |
It's odd, my IDTool says which sensors are faulty but I have tried to hear ticking from the other sensors but no joy. Am I going deaf or most likely being stupid and if the car senses a faulty sensor it deactivates them all. In which case the ticking test is pretty pointless anyway as none will tick |
No sir, you will still hear the ticking from the others when one is defective and the orange light flashes as faulty... |
A good tip that about the trailer board. Plugged one in but just the same. So that would point to a fault at the front.
Got the rear bumper off & changed the wiring loom and hey presto all working again |
So the IIDToll is specific, front right and rear right and centre showing as faulty sensors. However what ever I do there is no ticking. I've connected a trailer board (disables the rears) and when I run the scan this just shows the one fault Front Right sensor but there is no ticking at all.
Pvw10 Member Since: 04 Nov 2015 Location: Ledbury Posts: 315 ![]() ![]() ![]() |
Does the rear bumper have to come off or can you carefully lever them out ?
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
Get a proper colour matched aerosol from a paint factor and paint them yourself. Really easy to do and will save you a fortune. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
Good one, thanks.
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 ![]() ![]() ![]() |
Been looking at this thread , the rear bumper does need to off and after that relatively easy to access rear sensors. Front bumper not sure , I have just purchased the IID TOOL and the signs are that the switch on the dash is the culprit , sporadic though sometimes the when selecting revers its fine , but mostly not. It produces a continuous tone when wrong , not seen it flashing though. The diagnostic also picked up inner front left when I put a tick in the box on the tool except the one I mentioned , is this another way of detecting the problem . I know on the freelander 2 , that if one fails they all do which is indicative of the continuous tone.
