Home > Technical (L322) > Intermittent rear wheel squeal
Sandalwood
2011 Range Rover HSE 5.0 V8 Atacama Sand
I have noticed on my 2011 RR with 60,000km, an intermittent squealing noise originating near rear wheel on drivers side (NA vehicle).
Easiest to hear at less than 50 kph (30mph).
Disappears when I apply the brakes.
Occurs when traveling in a straight line, though sometimes worse if I steer right and other times left.
Any thoughts as to cause/origin of the noise?
Thanks
Post #276236 17th Aug 2014 10:25pm
Sounds like a sticking caliper.
Check disc temps 10mins after stopping by touch, is one much hotter than the other? There is nothing that can't be fixed with a hammer😜😜
Post #276239 17th Aug 2014 10:36pm
The pads are probably a bit rusty at the edges and not moving freely in the caliper. Take them out, scrape/file the rust off and put lots of copper grease on them so they don't stick again. Previously..
Post #276242 17th Aug 2014 10:53pm
Sandalwood
Thanks, will do some investigating.
Post #276246 17th Aug 2014 11:08pm
Agree with contra on that, was what happened to mine, not sure if they are exactly the same type as mine but the pad carrier corrodes and binds the pads in, best to remove caliper and carrier and clean the carrier out with a file where the pads sit then plenty of copper slip on the pad ears.
Good first point of call and if pads are still ok a cheap fix.. There is nothing that can't be fixed with a hammer😜😜
Post #276249 17th Aug 2014 11:38pm
pld118
I'll be interested to hear the results Sandalwood as ours has been doing this at the front since new discs and pads were fitted. Started off as squeal when the brakes were applied so removed pads, copper greased them and it disappeared... And now it comes on intermittently in a straight line but will sometimes do it on slight left steer... And always stops if the brakes are dabbed. Suggestions have ranged from sticking caliper to dry bushes. Doesn't do it in wet weather either. Ongoing and very irritating so good luck Thumbs Up
Post #276266 18th Aug 2014 9:21am
supershuttle
Mine made a bit of a noise which came and went but the real test was (as someone has pointed out already) that a rear wheel got hot after even a short journey pointed to a sticking caliper which I had replaced - fixed. Very Happy Geoff
Post #276270 18th Aug 2014 9:41am
Sandalwood
IST test
Took vehicle for 20 minute drive last evening and noticed squeal. Immediately checked caliper temperature (by touch) and calipers on all 4 wheels seemed cool to touch.
Post #276477 19th Aug 2014 12:16pm
pld118
Same here Sandalwood, no obvious symptoms of sticking front calipers which are Brembo. Our front brakes started giving a little squeal under light braking last night again too... So I'm again moving away from dry bush theories and leaning back towards some form of pad related friction.
A little frustrating.
Post #276483 19th Aug 2014 1:24pm
Its the disc which gets hot, not the caliper as such, which is why to check after 10 mins because they will all be hot after a drve but if one is still warmer to touch than the rest after 10 mins your pads are binding. There is nothing that can't be fixed with a hammer😜😜
Post #276519 19th Aug 2014 5:22pm
Sandalwood
2ND test
Tried "touch test" on rotors last evening, no apparent temperature difference from one side to the other.
Post #276663 20th Aug 2014 1:43pm
Sandalwood
3RD test
Purchased an infrared thermometer today (on sale at local automotive store). Confirmed rear disc/caliper on drivers side was 3 - 4 degrees C warmer than passenger side. It is the rear wheel on the drivers side which seems to make the noise. Everything seemed to be making sense until I checked the front discs/calipers and once again the drivers side was 4 - 5 degrees C warmer than the passenger side and there does not appear to be any noise from the front wheel!
Post #276802 20th Aug 2014 10:53pm
I would say that is in tolerance when mine binds, which it has done many times now the caliper is a good 20-30deg warmer (one will boil spit the other side wont) technical i know.....
Might be worth removing the pads and applying a good dose of copper slip to the back and ears. And see how it goes. There is nothing that can't be fixed with a hammer😜😜
Post #276806 20th Aug 2014 11:02pm
