Home > General > 4.4TDV8 Buying/Owning advise please.
Page 1 of 3 123>
Just purchased a 2012MY 4.4TDV8 & as they are newer than we usually see in the workshop for maintenance etc (as still under JLR warranties) what are current owners finding issues with other than the usual common niggles? All comments gratefully accepted please Bow down
No pics as i don't collect it until i return from my hols... Thumbs Up
Post #276196 17th Aug 2014 6:54pm
Colour scheme?
Sounds fab Thumbs Up
Post #276197 17th Aug 2014 6:58pm
Stornaway & Black inside... Thumbs Up
Post #276198 17th Aug 2014 7:00pm
Yes familiar with that scheme very nice too Very Happy
Post #276199 17th Aug 2014 7:07pm
JAYBOY
No real problems.
Battery is Censored but you know that.
Enjoy it Craig as I'm sure you will. looking forward to some pics Thumbs Up 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 JCW Mini Cooper
2018 Skoda VRS
Post #276202 17th Aug 2014 7:29pm
Vogue
No issues with mine at all, had the battery recall done and its been trouble free - even the FBH works without issue. There are several software updates for the reverse camera, the radio and AC fan system - all good though touch wood Thumbs Up
Enjoy her, you won't regret it - they go like stink without having to worry about the furl cost Cool 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #276204 17th Aug 2014 7:40pm
My mind got finally made up by the 8 speed gearbox... Seems so much better than the 6 speeds... Thumbs Up
Post #276207 17th Aug 2014 7:45pm
dhallworth
Sounds like a lovely car Craig!
Our 2012 is on it's 2nd alternator and has started clicking again now.
Post #276211 17th Aug 2014 7:47pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Low battery warning (two dealers failed to remedy), dead starter motor, injector-related hesitation (fixed), very, very occasional hanging on to second(?) gear, corrosion on side window and tailgate trim, foam block in door shut/inner-wing fell off.
Post #276215 17th Aug 2014 8:02pm
craig-meister, do pop down for coffee and show it off to me.. Wink ... - .- -.
Post #276222 17th Aug 2014 9:06pm
woodchip
Last week mine had 3 new door top surrounds, the black bits, and new tailgate struts due to corrosion a new temp sensor, new rear suspension dampers and a gearbox update all on warranty. This is the second 2 1/2 yr FF iv'e had that needed new dampers/ struts. And the car came back spotless. Result. Very Happy
Post #276228 17th Aug 2014 9:21pm
bwelton
United Kingdom 2012 Range Rover Vogue SE TDV8 Zermatt Silver
My Waranty ends in November. I'm not sure how to check what has been done on Recall oris possibly outstanding. How do I find out ?
As far as I know, nothing has been done.
Any advise welcomed of how to get everything done before the waranty ends.
Many thanks
Post #276254 18th Aug 2014 8:27am
ring your dealer and give them your vin number and they should advise you.. ... - .- -.
Post #276255 18th Aug 2014 8:54am
The dealer will be more than happy to sort out anything and check for updates/recalls as they get paid direct for it, pop in and ask them to check the car over and see what needs doing, did it with a Lexus a few years back and they found loads to do.... Including a wheel refurb when they found a small bit of corrosion on the inside of one of them.... Pete
-Click here for Thread-
Post #276256 18th Aug 2014 8:59am
When i viewed the car (and before starting) it was saying power save mode (or words to that effect) but started 20mins later without hiccup... Is there a tell tale sign if the battery mod has been done?
Post #276257 18th Aug 2014 9:00am
Page 1 of 3 123>
