Home > Technical (L322) > TdV8 - what does this pipe do ?
ksskaret
Norway 2010 Range Rover Autobiography TDV8 Santorini Black
I did a terrible mistake today while jacking up the front end. I put the jack under the front end sub frame and the jack slipped Big Cry
The jack went through the engine splash shield and hit a tube Censored Its now almost flat.
I removed the splash shields and followed the tubings route - it appears to end up on each side of the engine and one of the ends goes into the radiator area.
(center of the pic - the upper pipe/tube)
Is this a coolant tube? what does it do? It has no leakage so far.
I have tried to find the part in the http://lrparts.net.ru but haven't succeeded yet Shocked
Could it be the condenser refrigerant lines?
Any help most appreciated Bow down Range Rover TdV8 Autobiography MY2010
Defender 110stw Td5 MY2006
Post #276348 18th Aug 2014 6:04pm
vaz
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Looks like it is to do with the air con system.
Next time you use the motor, run the air con to see if it still works. Might be ok if it has not crushed it too much and provided it does not offer too much restriction.
If it is not so good, maybe an air con shop might be able to swap it out and re-gas the system for you.
Steve.
Post #276382 18th Aug 2014 7:41pm
Dijit
Scotland 2007 Range Rover Vogue TDV8 Java Black
Should be easy to cut out the crushed section and install a new piece of pipe with two straight connectors. Rehab is for quitters!!!
RR 2007 3.6 TDV8 Java Black *
RR 2007 3.6 TDV8 Zermatt silver *
RR 2000 P38 4.6 Met red *
Mercedes 300TE 4-Matic *
Jaguar 420 (1969) *
Nissan 300Z
Citroen XM 2.5TD X 6
Bentley Continental R
Hydrocon Highlander
Hydrocon Hamilton
Hydrocon Huntly
Am told the ones with a * are to be offered for sale! 😳
Departed
LR 1992 110 2.5TD
RR 2000 Holland & Holland 4.6 LPG
RR 4.2 Supercharged with LPG, Vogue SE 2007 Buckingham Blue
RR 2002 4.4 V8 Zambesi Silver
Post #278146 30th Aug 2014 9:40am
