Home > Maintenance & Mods (L322) > Battery booster pack advice
jj2908
2007 Range Rover Vogue TDV8 Java Black
Chaps. Great advice about the jack. Whilst setting up a bike rack I flattened the battery with all doors open and lights on and off. I got the battery back with my optimate. but think I might need a v8 capable booster pack. Any recommendations?
Cheers
Post #274933 8th Aug 2014 9:01am
http://www.tayna.co.uk/Varta-Car-Batteries...mp;A-7=110
Thumbs Up .
Post #275014 8th Aug 2014 9:15pm
jj2908
Thanks joe. I was thinking more of the batter booster packs that you can charge up and take with you?
Post #275065 9th Aug 2014 10:31am
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
This one does the job on my 3.6 TDV8 on a cold morning...weighs a bit but hay'ho
They do a few others if you type in "jump Starters"
http://www.maplin.co.uk/p/5-in-1-power-sta...ssor-a67hy GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #275067 9th Aug 2014 11:14am
@ jj
My response was a bit tongue in check, but notwithstanding that, it will get you going! .
Post #275068 9th Aug 2014 11:37am
sako243
Only if you haven't left it plugged into the car to charge when you're in the process of flattening the battery...
Post #275095 9th Aug 2014 5:18pm
tsadpt
Yep, that maplin one worked for me when my last battery was on its way out...
Post #276032 16th Aug 2014 9:27am
Just get a long fat set of jump leads, they will suffice in most situations...... And you don't have to remember to charge them. There is nothing that can't be fixed with a hammer😜😜
Post #276033 16th Aug 2014 9:31am
iphs
England 2003 Range Rover Vogue Td6 Buckingham Blue
I go along with northernmonkeyjones on this one. Jump leads are an essential.
Booster packs are good if you use and recharge them on a regular basis. Thet are not good at sitting around unused for any length of time and most have no overcharge protection built in (that is assuming you remember to charge them).
I also subscribe to a fair amount of paranoia, and never ever work on the car with doors open unless it is also connected to a charger.
Post #276390 18th Aug 2014 8:54pm
If your working underneath you should leave a door open, it will stop the suspension deciding to self level... Pete
Post #276409 18th Aug 2014 9:53pm
iphs
I would advise never to work under the vehicle without axle stands. My opinion.
Post #276422 18th Aug 2014 10:37pm
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
^+1, NEVER rely on the air suspension to prevent you from being crushed!! Thumbs Up 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #276469 19th Aug 2014 11:01am
For something truly portable and with many uses besides jump starting, try an Anti-Gravity Battery.
I'm perfectly serious. These things work! I bought one thinking 'yeah, yeah...' but it jump-started my 3.0 diesel Mercedes motorhome from dead flat with ease.
http://www.antigravitybatteries-uk.co.uk/m...arter.html Si. <This is my name.
Post #276475 19th Aug 2014 11:29am
SoggyBottoms
United Kingdom 2007 Range Rover Vogue Supercharged Zambezi Silver
I've started getting interesting in RC stuff - mainly multirotors.
these use LiPo's, as in the antigravity, and there are routine accounts of people using their RC lipo's to jump start trucks on RC forums. even a small battery for a DJI phantom can push out 95amps and peak at nearly 190.
they are serious bits of kit that need to be treated correctly. if you short one it will melt metal...don't ask how I know Smile
Post #276480 19th Aug 2014 12:49pm
