Home > Maintenance & Mods (L322) > Reverse camera replacement
davidjpowell
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
The reverse camera on our FFRR died. Found this chap on da bay who,has installed an upgraded camera in the same housing. Better picture and substantially less costly then replacing with oem.
http://www.ebay.co.uk/itm/321484664857?_tr...EBIDX%3AIT
Finished picture
Thought I'd share....
Ps this bloke is dangerous. Keep your wallet shut to avoid tempting upgrades....
Post #276529 19th Aug 2014 6:55pm
Av_dave
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
good job, i can't believe how pants the standard camera really is The difference between theory and reality is that in theory it will work.
Post #276535 19th Aug 2014 7:35pm
£160!!!...a bit steep me thinks. Neutral ... - .- -.
Post #276539 19th Aug 2014 8:08pm
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
That looks very good! Mine is sometimes intermittent, so I might just try this. Did you go there or did you send your old one?
How long did it take?
Thanks in advance Thumbs Up
Post #276545 19th Aug 2014 8:36pm
davidjpowell
I went there as I was in the area. Took about 30 minutes.
I may have paid slightly less than £160.... I think the LR item was £450 or so.
Post #276546 19th Aug 2014 8:41pm
Robert
Thumbs Up will see if it is difficult for a non tech like me to take the old one out
Post #276548 19th Aug 2014 8:45pm
davidjpowell
Taking it out looked pretty straightforward.
Bit more patience getting it in as new connectors were added that were a little larger and needed squeezing through. He rewired the new camera with the old loom after these connectors so that the fitting was otherwise plug and play
Post #276551 19th Aug 2014 8:59pm
SoggyBottoms
United Kingdom 2007 Range Rover Vogue Supercharged Zambezi Silver
he's doing it a bit cheaper here http://www.ebay.co.uk/itm/Landrover-L322-F...4ada58e4fc
Post #276560 19th Aug 2014 9:56pm
davidjpowell
That's apparently just a replacement camera mounted next to the existing....
I'm not convinced, but I'm happy with what I got and the saving on OEM.
Post #276565 19th Aug 2014 10:05pm
Silversurfer13
United Kingdom 2008 Range Rover Autobiography TDV8 Java Black
I'm wondering if they can upgrade it to a DayNight / Infrared LED style camera??
I think i might write to the seller and ask.
Post #276652 20th Aug 2014 12:31pm
