![]() | Home > Maintenance & Mods (L322) > Brake Squeal & Removal of pads without removing calipers |
| alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6837
I've got the front discs and pads to replace ok mine, so now you're fully time served, could you do mine?
| pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218
A brave man! |
| mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 913
Front discs aren't that difficult to do either.....just a step on from doing the pads. You will need to remove the caliper from the carrier.....a 7mm allen key, then remove the carrier, 17mm socket or ring spanner. Once the carrier is off, you will be able to remove the hub locking screw, allen key again (i think) then the disc will fall off. When reassembling, make sure to clean everything and then clean it again. you need to make sure the new disc sits cleanly on the hub so the disc rotates properly......and did i mention cleaning? Make sure to clean the protective coating from the disc too before replacing the carrier, caliper etc. Oh, and don't let the caliper hang on the hose.......it'll stress the hose unnecessarily. |
You clearly missed the entire meaning of my post! |
The squeal is back!
I'd like to think I didn't, but as you can see from the rest of this post, all it needs is a minimum of tools and a level of confidence to do a lot of DIY mechanics and i'd encourage anyone to have a go. But if I did miss it.... |
Squeal is intermittently back! |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8788
Check its not the rears binding...... Can sound like the fronts depending on which way the wind is blowing |
All new calipers discs and pads on the rear too though... Will check |
Was informed by a listener that the squeal (worsening IMO & at times embarrassingly loud) has definitely maybe been coming from the front driver's side wheel.
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
squeak,squeak,squeak......................
Well... Been raining and damp but after a wee bit driving today including on warmed up dry roads, nothing from the driver's side yet and it all does appear more velvet like down there again , ahem.
here's a thought ryan, how about directing a pressure washer at the calliper/brakes to get rid of any brake dust or crud.. ... - .- -.
