![]() | Home > Technical (L322) > Adaptive light module |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35829 ![]() ![]() |
give ducky dan a pm , he might throw some light on this... ... - .- -.
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 ![]() ![]() ![]() |
Do you know for sure that you have the adaptive lights on your vehicle.
mk1paul Member Since: 01 Jul 2014 Location: Hampshire Posts: 109 ![]() ![]() ![]() |
Hi
i gather your headlights are like the diagram with the cornering bulb [number 5] in it,
Yes that's right.
sounds like you need to get some diagnostics done on it..might be worth investing in an iidtool which will allow you to get the codes and do loads of other stuff as well.. ... - .- -.
I wondered if it was just the AFS module needs replacing.
Exactly the same as mine. Given up as they work as normal lights and no ideas on how to fix or even confirm tha they are wired up and not just replacement lghts from another FF There is a difference between knowing your sh!t and knowing you're sh!t
