Home > Technical (L322) > RR Air Suspension Trouble - Again.
theanswers
Ireland
Hello Guys, as some of you may know my air suspension has been playing up. Originally the suspension was locked into normal height and the system would maintain that height, whilst not accepting commands to change to either access or off-road mode.
Until I got time to sort this, I was happy with this as normal height provides most adequate for most of my off-roading needs whilst also being acceptable for towing.
However, recently that lights on the ride selector have disappeared; and the car is no longer attempting to maintain the normal height. This is causing me trouble when I place a heavy loaded trailer on the Land Rover. What should I do? The air bags are perfect and there is no leaks. I've checked the fuses and they are ok. Is something more serious wrong, given that the LEDs no longer light up at all.
To demonstrate the problem; I've uploaded a video to You Tube.
&feature=youtu.be
Post #277180 22nd Aug 2014 9:09pm
Buy an IID tool and reset it or take it to an Indie or the dealer for them to do.... Pete
-Click here for Thread-
Post #277181 22nd Aug 2014 9:21pm
theanswers
Ireland
Thanks. I was looking into doing this; however, they all seem rather expensive for a once off use. If I was to buy one, which would you recommend?
Post #277182 22nd Aug 2014 9:26pm
Buy the best you can for your model (the IIDTool BT). It won't be a one off use, you will find many things to do with it, trust me!
See here for what it can do:
http://www.gap-diagnostic.com/products/iidtool.html#c309 .
Post #277185 22nd Aug 2014 10:52pm
What he said...... I haven't got the BT one and it works fine and is cheaper.... we like cheaper.... Whistle Pete
Post #277186 22nd Aug 2014 11:25pm
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
As above, iid tool, I thought the tool would be a one of job to sort out things......oh no, its paid for its self as the eas has having an issue.
Its worth it in the long run and would need the fault codes to diagnose your issue.
I too have the non BT version. If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #277193 23rd Aug 2014 7:22am
theanswers
Ireland
I like the idea of cheaper. What's everybody think of the All-Coms? It seems better in the fact that it's not limited to one specific RR?
Going to place an order on one of the units this week just deciding which one. Hmmm.
Post #277201 23rd Aug 2014 9:51am
support from the rws all-comms is pretty well nil , whereas the gap chaps are site sponsors and regular visitors to the forum and they answer queries via pm/email very quickly .. ... - .- -.
Post #277204 23rd Aug 2014 9:56am
theanswers
Ireland
I was thinking; If one sourced the All-Coms. I could give assistance to individuals with other RRs and therefore possibly recoup some of the cost. Furthermore, I do buy RRs from time to time and would find it handy to be able to sort issues on the other RRs.
Post #277207 23rd Aug 2014 10:11am
for standard error clearing the iidtool is vin free..........
have a read here, http://www.fullfatrr.com/forum/topic22489.html ... - .- -.
Post #277209 23rd Aug 2014 10:16am
theanswers
Ireland
If the GAP firm could provide something similar for me at a reasonable cost. I would be interested. Keeping it local and all that.
Post #277210 23rd Aug 2014 10:17am
theanswers
Ireland
Ok guys. so you were right. It only needed resetting.
After having a good look online and at various supplier I stubbled upon the iCarSoft tool on eBay. At 106 pounds it represents great value for money as it can read and clear faults in all of the Land Rover Family of vehicles, or at least most of them.
For me it solved my problem, whilst providing me with a low cost tool to diagnose any issues which I may have in the future.
Well worth it.
http://www.ebay.co.uk/itm/291152877691?_tr...EBIDX%3AIT
Post #278212 30th Aug 2014 5:29pm
theanswers
Ireland
Another unexpected result.
Ever since I've owned the RR the power steering wasn't working correctly. It was as if it only worked 50%. I've used RR with the power steering not working and turning the wheel was very difficult as one can imagine, mine however wasn't that bad. But it wasn't working perfectly.
Using my new diagnostics tool, I erased the faults in the steering system and low and behold it's not working fine.
Best 106 pounds i've spent in a long time.
Very Happy
Post #278376 31st Aug 2014 9:01pm
