![]() | Home > Technical (L322) > Transmission problems |
Netvet Member Since: 25 Aug 2014 Location: Derbyshire Posts: 19 ![]() ![]() ![]() |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1014 ![]() ![]() |
Can you read the transmission model number stamped into the casting :
Okay. The TGD500481 was only fitted to 4.4s with a VIN between 6A206378 and 6A236915. I can’t make it out from the photo but can you confirm that the ZF model number is 1068 020 064 ?
Phil Do you think that the casing will be alright or would that need replacing ?
I have a Jaguar casing (which is of no use to you) and a Range Rover 4.2 S/C casing in my garage at the moment for the 6HP26. Maybe all the Land Rover petrol-engined 6HP26X casings are identical (they all mate with the same transfer box) and, knowing ZF, the part number differences may well just be because the transmission uses a different torque converter or calibration in the Mechatronic unit and otherwise the hardware is identical but, nevertheless, there’s a risk that they aren’t exactly the same (RFOB bolt pattern?) so I would suggest re-using your existing casing if you possibly can. How deep is the gouging into the casing (compared with the wall thickness)?
Hi phil
If you can make it to Leyland in Lancashire on a weekday during working hours then you're welcome to collect.
Thanks phil how much would you want for the
You can have the sun gear shaft and clutch plates for £30 and then another £30 for the casing if you decide it’s identical. What state are the steel plates in from your B-clutch?
That sounds perfect my next few questions was going to be do they do an overhaul kit for it , if you have a set of steel plates with the friction plates I'll have those as well as they have been hot but don't look too out of shape
Hi phil
fanders Member Since: 10 Jul 2013 Location: Hants, UK Posts: 318 ![]() ![]() ![]() |
RRPhil = legend |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
+1 |
