![]() | Home > Technical (L322) > Air con not working, but has pressure |
Normally if the pressure increases that means the compressor is working. However the increase in pressure is a bit low for my liking so you may be right. Have you tried a proper A/C specialist that knows how to fault find A/C units ??
Mistercorn Member Since: 01 Feb 2014 Location: Nottingham Posts: 109 ![]() ![]() ![]() |
The fan is running normally and blowing air in to the cabin. It was the lack of serious pressure rise which makes me think it is the compressor, almost as if the compressor failed when it ran of gas previously. None of the normal water you would associate with a fully working system.
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
Think I had a thread somewhere showing AC pressure when off and on |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35863 ![]() ![]() |
i wonder if the belt might be to loose or broken or ,as mentioned , the compressor is knacked ... - .- -.
I will check the belt, but there are no noises from it, I'll give my local specialist a call and see what they suggest. I'll report back.
It might also be worth checking the compressor clutch. This can slip and lead to minimal gas movement even though all looks well from the front. I had this years back on a Vauxhall Senator and it took a wee while to diagnose.
Thanks, I will check that. I have also spoken with my local specialist who suspects the compressor. His suggestion is to get a secondhand one and fit that. A couple of hours later and all should be good. He can recover and re-use the gas / oil. Off to eBay for me then....
