Home > Technical (L322) > Alternator + battery replacement cost
Page 3 of 3 <123
RR2008HSE
Yes, Nomad.
If it CAN go to 14.8V, you're fine. It doesn't have to always be there. As long as you know that it can do it, you're good.
Post #277815 27th Aug 2014 11:46pm
FrankRizzo
Germany 2012 Range Rover Vogue 4.4 V8 Santorini Black
Interesting to know. On the way home yesterday it stayed at a constant 13.5v for about 10 minutes and then dropped to a constant 12.5v thereafter. I was wondering if anything regulated the alternator output or whether it just always gave everything it had... 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
2008 Vogue 3.6 TDV8 automatic (LHD), Java Black
Post #277892 28th Aug 2014 3:18pm
Frankrizzo it sounds like you have a failing alternator, you need to test with a bit more load on it. It should stay up in the high 12s with mucho load on it. Put on the rear screen heater, front screen heater, heated seats front and back, when running obvoiously.
The voltage should not dip much. There is nothing that can't be fixed with a hammer😜😜
Post #277900 28th Aug 2014 4:32pm
I've picked up four voltmeters over the years, when I fitted a voltmeter to mine it seemed to read low so I checked it with the other four... There was a 2volt difference between them, and the one I think is closer to the truth was a cheaper one of the four..
So, I wouldn't worry too much about what it reads as long as it doesn't drop...
Don't know about yours but I'm sure I've read somewhere that mine has a variable output between 90 and 140 amps... Pete
-Click here for Thread-
Post #277901 28th Aug 2014 4:35pm
FrankRizzo
That would annoy me immensly as I've just had a new one fitted. I did try sticking aircon, stereo and seat cooling on and that didn't change the voltage at all but I didn't try anything else. Will have to do it on a wet night where I can do lights and wipers as well... 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
Post #277902 28th Aug 2014 4:35pm
If its not dropping then you may be fine alternator wise, the main problem is the output breaking down under load. If it can cope with load being applied without the voltage dropping then it sounds ok to me, when mine was on its way out the voltage would spike to way over 15v as the charge phase kicked in and then settle in the low 12v range, but when I switched stuff on the voltage would drop to around 11v.
I know it sounds obvious but have you checked all the connections to the battery and alternator for tightness? There is nothing that can't be fixed with a hammer😜😜
Post #277953 29th Aug 2014 5:52am
wealy
I have just replaced my alternator with a brand new denso unit and it shows 14.30 volts after running for a while. If I switch everything on (seats, f & rear screens etc) it drops to 14.20v
Post #278481 1st Sep 2014 2:26pm
FrankRizzo
@wealy: On the volt meter or on the diagnostics screen? 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
Post #278560 1st Sep 2014 11:49pm
wealy
I din't know about the diagnostics screen until yesterday so it intreagued me to check both. I have just done it and it is 13.8 on the screen and 14.12 on the volt meter.
I put front and rear screens on and heated seats and it went down to 13.7 on the screen and 14.05 on the volt meter?
Post #278570 2nd Sep 2014 7:24am
FrankRizzo
I might pick myself up a volt meter. Had 14v on the screen for the whole journey home today (about 30 minutes), the highest I've seen it so far... 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
Post #278739 3rd Sep 2014 12:25am
Page 3 of 3 <123
