![]() | Home > Wheels & Tyres > Help needed on lockingwheelnuts |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8817 ![]() ![]() ![]() |
The dealers should have a full set of the tools, take it there and get them to check them.... Pete
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2291 ![]() ![]() ![]() |
Thanks Pete
In that case, check what size they are and get some of these....
There is no easy solution Robert... BUT PLEASE HEED THIS WARNING!!! DO NOT let anyone try chiselling them off! They are a two piece unit and the outer is made to brake if anyone tries stealing them and is made of some kind of super hard grade of steel that can only be drilled using special drill bits etc etc...
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
for £25, makes one wonder why we bother with locking wheel nuts |
Pete, absolutely and positively will not work on 06> FF's sir... |
I did wonder if they'd work, had the earlier ones on mine and they would work for them but now I've got the later wheels I didn't bother with locking ones, they get full of mud and don't work that well on an offroader....
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3956 ![]() ![]() ![]() |
Craig, how many different ones are there? I took mine off and chucked them, after all it's difficult enough getting the wheels off a Range Rover |
Not sure Geoff, we have 8 or so of them here but I just don't know just how many different types there are? They are lettered A, B, C etc but I'm unsure if its every letter is used or not? |
I believe they have to be drilled using a really really expensive super hard drill bit ![]() ![]() |
Well you all made me very happy and positive |
Oh yes Geoff, good idea but Looking at these nuts I don't see anything to distinguish them from other nuts |
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217 ![]() ![]() |
think the problem with the code on the nuts is that its stamped on the side from memory so near enough impossible to see with the nut in place You can paypal direct using - www.paypal.me/duckworthparts
Thanks, what would a complete set of "unlocknuts" cost me Dan? |
