![]() | Home > Technical (L322) > Transmission problems |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1014 ![]() ![]() |
C’mon guys - it’s only a gearbox |
I strip all my transmission down completely so that I can clean & check all of the components, so they’re all stored separately rather than as assemblies, I’m afraid.
Netvet Member Since: 25 Aug 2014 Location: Derbyshire Posts: 19 ![]() ![]() ![]() |
Yes phil i have also stripped mine down completely had to make a tool to remove the pistons and I have ordered a rebuild kit aswell as a replacement plate for the valve block I've found someone to also test and rebuild the tc also
Steve,
Bit of an update box now rebuilt many thanks to phil for supplying the parts to fix it took a while to replace all seals but got there in the end, I decided in the end to send the valve block off for testing and should get back later this week, just one question is their an easy way to refill oil and what's best way to test temperature ?? Many thanks steve
