![]() | Home > Wheels & Tyres > Corroding TPMS valves. Costly and worrying |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8119 ![]() ![]() ![]() |
Seems to be a very common problem.
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
IIRC TPMS is only a failure on vehicles registered after 2012. If registered before then its only an advisory.
Re. the broken valves - I keep a compressor in my boot for emergencies and use this to check tyre pressures
0949 Member Since: 01 Nov 2013 Location: Notts Posts: 19 ![]() ![]() |
Many thanks for some informative and helpful suggestions. Apparently the monitoring system on my 2012 BMW F11 runs off the ABS which seems a good deal less clunky to me. |
The passive systems have much less to go wrong, but are less accurate than active TMPS systems
taskam Member Since: 01 Apr 2011 Location: Shandon Posts: 121 ![]() ![]() ![]() |
I was told to only use plastic valve caps with the RR TMPS valves, as the metal ones cause faster corrosion (sacrificial metal and other black magic) 2007 TDV8 Vogue SE Java Black |
steve9bug Member Since: 25 Aug 2013 Location: sunderland Posts: 356 ![]() ![]() ![]() |
If you put standard valves in can the tpms not be turned off like on other cars |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35850 ![]() ![]() |
i did that with an IIDTool Steve.. ... - .- -.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6382 ![]() ![]() |
Stan,
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6836 ![]() ![]() ![]() |
Dealers refuse to turn off TPMS on the grounds that it's a safety feature (their diagnostics kit won't allow them to), but as Stan says, and I can confirm, it can be turned off with an IIDTool! |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
Gents,
I've only heard of the corroded valve snapping when attempting to use compressor. I guess they could just give way on their own in the right (or wrong really) conditions 2007 TDV8 Vogue SE Java Black |
Si,
Ryan, in this instance it doesn't, but I get where you're coming from. |
