![]() | Home > Wheels & Tyres > Corroded TPMS Valve? Almost An Obvious Question |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
I've just changed my front wheel following a rapid deflation this morning.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
thats what happens .. |
Thanks. |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8064 ![]() ![]() ![]() |
If one valve has gone, then the others can't be too far behind...... |
You're right.
Can you just not un-plug the ECU or for that matter pull a fuse?
No. If another valve goes suddenly like it did yesterday, it's potentially lethal.
is it the rubber ones you are going to have fitted? . ... - .- -.
I don't know yet.
pretty sure that the new tpms valves will be automatically detected by the FF's system and the dash light error should switch off..
Si,
OK, I've decided that the non-OEM TPMS valves could be a short-term thing. I don't know, but I don't want another failure and I'm somewhat unsure of the quality.
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
I replaced my TPMS valves when I replaced my tyres 18 moths ago with new OEM ones (Siemens JLR) purchased for about £50 from eBay
50 quid is good, we were told that main dealer would be around £400 for new valves and fitting from memory |
