Home > Maintenance & Mods (L322) > Sometimes it does - sometimes it doesn't
supershuttle
Car sometimes settles down at the back when parked overnight but sometimes it doesn't - I'm not losing any sleep at the moment but should I be? Geoff
Post #278597 2nd Sep 2014 10:28am
if you park on a flat surface then it could be a small leak but if its on an incline it might be levelling off.. ... - .- -.
Post #278600 2nd Sep 2014 10:34am
mavester
Are you referring to the suspension dropping after you switch the car off? Mine does this sometimes but not all the time, as far as I can tell. It happens after I reverse down the drive (and slight hill) and then turn the car off an close all the doors. I think it's completely normal.
If it's dropping lower than it should then you might have an issue.
Post #278626 2nd Sep 2014 1:43pm
