Home > Off Topic > SQL Server question
mzplcg
SQL Server question
Hi chaps. A quick SQL query (awful pun intended) if I may please.
Can I have different Locales for each database on a SQL cluster? i.e. each database has it's own locale and timezone
OR (as I suspect)
Does MS-SQL Server take the locale from the underlying OS (Windows) or from the SYS database which manages the production databases.
SQL 2012 on Windows Server 2012.
Ta
Dom
Post #278794 3rd Sep 2014 9:34am
stephen44
United States 2005 Range Rover HSE 4.4 V8 Java Black
not directly - you are right it just gets it from the OS.
However using UTC times with offsets will accomplish what you need probably.
see:
http://social.msdn.microsoft.com/Forums/sq...getstarted
look at the links in the answer with the blue tick against it.
also a worse pun...
a DBA walks into a bar and sees two sql queries sat at a table - he walks up to them and says "mind if I join you ?' Stephen
USA (originally from London) - 2005 L322 HSE
Post #278832 3rd Sep 2014 1:19pm
mzplcg
Thumbs Up That's kind of where I'm getting to. There seem to be functions in .NET for offsetting against UTC which might do what I need.
Post #278860 3rd Sep 2014 2:40pm
