Home > In Car Electronics (L322) > Which C Tek battery charger?
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
Anyone tried the tc ek connected through the 12v socket rather than directly connected to the battery, one in the boot to be exact?
Post #279345 5th Sep 2014 10:30pm
J evro
Message from seller
The XS0.8 charges sizes 1.2-32Ah (maintenance charges
1.2-100Ah). The MXS3.6 charges sizes 7-75Ah (maintenance charges 7-120Ah).
I think if you want to look after a charged 90Ah battery then you would be
better off with the MXS3.6 charger.
Post #279358 5th Sep 2014 11:33pm
mmiata
Hungary 2012 Range Rover Vogue TDV8 Buckingham Blue
I don`t know if anyone is worried about AGM battery recondition (which according to vendor differs from normal battery recond, and from AGM charging as well).
But according to user manuals of CTEK MXS 5.0, 7.0 & 10.0 only the 5.0 is offering this slightly modified program of AGM reconditioning. Then I called the local rep and he confirmed that the rest does not have this feature yet.
I don`t know if this observation is right, or representative was fully in picture, but I would be interested if anyone else noticed this.
Attached is the CTEK 5.0 charging program sheet showing AGM RECOND what all the others miss.
 4.4 TDV8 Vogue Buckingham Blue MY12
from Hungary
Post #279377 6th Sep 2014 7:16am
mjdronfield
J evro, your man is right. If all you ever want to do is maintain your battery, the 3.8 will be fine. It's a 3.8 on ctek webpage. If he has a 3.6 is it an older model ? Or a typo....
You'll be giving him another ring though if your battery goes flat, as it won't be able to recharge it.
The demands are different in each application, so you will get away with a smaller unit till the going gets tough.
My TD6 has a 110 amp battery, so the 5 will just about charge it. So I got the 7 to be safe, with the added benefit it will charge the battery faster.
Not sure about the AGM recond bit....... Don't have one of those batteries....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #279380 6th Sep 2014 8:06am
J evro
Thanks chaps ,
I'm sure my battery is 95ah? , I just want it hooked up out on the drive to trickle charge it if necessary really as I hear they're prone to flattening if left for long spells which mine probably will be,
Now I do not want to ask this question but.....load up your flame guns ..................what is an AGM battery Embarassed :oops...................INCOMING !!!
Post #279397 6th Sep 2014 10:35am
mjdronfield
I think it's some later gel type arrangement. Don't know much after that myself.
Google may help you more.
I spoke to the supplier of mine as I had a query as the cold setting on mine has agm on it. He said the cold setting uses the agm profile at the start.
To be honest, I'd get the unit that car charge your battery if flat, that way you've covered all bases. If your battery is 95 amp then the 5 will be fine.
If you accept you may struggle to recharge it, then indeed the 3 will do it.
Is the price difference that big ? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #279430 6th Sep 2014 1:57pm
J evro
Yes sorry being lazy , but I'd rather hear from someone on here as they sometimes add more info/ experiences I find Very Happy
"AGM, short for "absorbed glass mat", batteries feature fiberglass mesh between the battery plates which serves to contain the electrolyte. Both designs offer advantages and disadvantages compared to conventional batteries, as well as each other."
Every days a school day eh !
£55 #5
£90 #7
Post #279431 6th Sep 2014 2:05pm
mjdronfield
Nothing like what I thought then. Never really needed to know. Thanks for the info.
I'd get the 5 at that price. At least it should charge upto 110 amp.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #279433 6th Sep 2014 2:12pm
What are the problems (if any) of using a higher amperage batterie conditioner/charger ? 2008 MY Supercharged
Post #279529 7th Sep 2014 4:11am
mjdronfield
No problem, it will charge it faster. If you compare a 5 amp to a 7, the 7 should be 40 % faster on paper. Though won't get that much increase in the real world. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #279532 7th Sep 2014 6:44am
J evro
Grrrrr
Just seen one on eBay for £65 buy it now ....looked around to see it was the correct type then when I went back to buy it now the damn seller had removed it and put it up for auction Censored Censored Censored
Post #279552 7th Sep 2014 11:20am
