Home > Technical (L322) > Programming the remote for FBH
kin
England 2006 Range Rover Vogue TDV8 Zermatt Silver
Well..I've finally recieved my remote today .
The instruction for programming the remote is as follow:
Disconnect the battery or fuse59 for at least 5secs then reconnect and within 5secs press the unlock button for 1-5 secs.
I did that and its still not working Embarassed
Post #2787 3rd Feb 2009 7:37pm
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
Sorry to hear that.
I had mine done by the dealer, £45 + VAT
Post #2788 3rd Feb 2009 8:40pm
dark.soul999
Romania
Are you sure that remote its for FBH ?
The remonte for FBH has 2 buttons: ON & OFF (not lock/unlock)
Post #2794 4th Feb 2009 3:38pm
kin
Mine is definitely a FBH remote, but the instruction says press un-lock, so I pressed the unlock on ignition key Shocked Unless it meant "off" on the FBH remote Confused
Post #2795 4th Feb 2009 4:01pm
dark.soul999
Romania
Try this: remove fuse and wait 15-20 seconds, reconnect the fuse and within 5sec press OFF button from FBH remote. If this procedure its not work, try to repeat procedure with ON button. The red/green led from remote must lighting aprox. 2 seconds if all OK.
Post #2796 4th Feb 2009 4:54pm
kin
Thanks, just asked the dealer, remove fuse, I should press the "ON" button from FBH remote within 5 secs, NOT the unlock button from the ignition key....
Post #2797 4th Feb 2009 5:45pm
kin
Ok then...I've just tried again by pulling the fuse out, and pressed ON, tried again, then pressed OFF, not working Rolling Eyes
Tried disconnect earth on battery and press OFF, it worked straight away Thumbs Up
So I think the proper way to programme the FBH remote is as follow...
Disconnect the earth from battery for at least 15secs, then re-connect and within 5 secs, press the "OFF" button on the FBH remote for 1-5secs.
Its a 5minutes job Thumbs Up
Post #2800 4th Feb 2009 7:57pm
dark.soul999
Romania
My mistake Embarassed , but before to advise how to program the remote, should be ask what model year its vehicle. The electrical schematics it’s changed from MY 06 Thumbs Up
Post #2806 5th Feb 2009 8:48am
Should this not take 20 - 25 secs to do , not 5 mins Rolling with laughter Rolling with laughter Thumbs Up
Post #2807 5th Feb 2009 11:21am
At least we now know how it's done if anyone else requires instructions. Thanks Kin. Discovery 4 HSE
Post #2809 5th Feb 2009 11:49am
kin
Mine is MY 06,and your advice was right Thumbs Up
Mick..it's a 5min job, first you have to find a 10mm spanner to un-do the nut on the battery, and then re-connect and tighten the nut again Mr. Green
RRUK, no need to thank me, its all part of the service Mr. Green
Post #2814 5th Feb 2009 1:31pm
dan_uk_1984
Found it!
Post #36669 18th Nov 2010 2:15pm
