Home > Technical (L322) > Electrical gremlins? Help...
gav
United Kingdom 2003 Range Rover Vogue 4.4 V8 Bonatti Grey
Cant figure out what is going on...
For a few days I've been seeing the air susp. inactive message and bong coming and going along with the following:
no indicator flash on door locking/unlocking
even sometimes not being able to lock the doors
no steering wheel access movement on turning off the car
erratic mirror dipping/going back to memory position when going into reverse
car not recognising the key fob when in proximity and releasing steering lock
I thought it was a flat battery since it is very similar to what happened when I had to change out my battery 8 months ago
Bought a CTEK MXS 5 charger thinking this will solve the issue since we just did a fairly rare 250 mile journey with air con, lights, music, satnav, rear power socket in use and assumed the battery was drained.
According to the CTEK the battery has ok charge - didn't even take all that long.
Connected the IIDtool today and got:
EAS - 33--k bus fault
Instrument pack - 87--K bus fault
The EAS fault cannot be cleared - update failed
Also some of the ECUs say "no comm with ECU" when I try to read the faults.
Any ideas?
Post #277787 27th Aug 2014 9:07pm
All points to battery/voltage as you say. Alternator OK?
If you have a fault that won't clear, try emailing the GAP boys, they can probably assist with fault identification. .
Post #277793 27th Aug 2014 9:23pm
gav
Any way to check the alternator or do I need a volt meter?
Voltage test on the service menu reads 12.5V with everything off 13.5 - 13.8 with engine idling
Post #277803 27th Aug 2014 10:17pm
psgk
I had similar problems last year with the Air Suspension, Passenger Mirror not dipping on reverse, Steering Wheel not adjusting on turning off the ignition etc with my MY2002 Vogue.
It took my independant LR garage some time to trace but the cause was eventually found to be a K-bus fault due to the headlight levelling unit being U/S. Once this had been sorted all the other functions were restored.
Hope this helps Peter Kemp
Chelmsford
UNITED KINGDOM
Post #277870 28th Aug 2014 1:58pm
gav
This could be it as the k bus has a fault on the iid tool. Waiting to hear back from gap team now.
How much did it cost you in the end?
Post #277871 28th Aug 2014 2:14pm
psgk
Hello gav,
My garage said it took them three hours to trace and repair the K-bus fault @ a labour rate of £72 an hour (October 2013) if this is any help. It doesn't look from the invoice if they had to replace any parts in curing the fault.
My total bill for repairs was £687.67 but this also included tracing and repairing a very bad leak in the AC (Low Pressure Pipe replaced / re-gassing) and trying to trace the cause of the Engine Management Light coming on intermittently (possible O2 sensor).
One of the lower cost garage bills for my RR!
Best Wishes Peter Kemp
Chelmsford
UNITED KINGDOM
Post #277960 29th Aug 2014 8:34am
gav
Well that doesn't sound too painful. I got a fantastic in depth response from Patrick at gapteam for finding the fault. I tried a hard reset which didn't help. Next I will check all fuses and the headlight ecus.
After that it will have to go in.
The problem now is that the steering wheel controls have also stopped working so my iid tool is also useless.
Post #277992 29th Aug 2014 12:13pm
gav
Here is an update:
Took it into my local Indy last week because after the fantastic help from Patrick at Gapteam, checking fuses and a hard reset, it wasn't getting any better and I didn't want to start pulling out ECUs.
Indy scratched his head and said he has never seen a K-bus fault before but we booked it in for this Monday and he will work through the wiring/ecu suspects with the diagnostic tool technicians on the phone.
Meanwhile the other day, I noticed while fiddling, that the drain pipe situated in the battery bay that connects to below the windscreen was disconnected. The carpet in the passenger foot well was wet too. connected the pipe back up and dried out the carpet a few days ago.
Today: All errors disappeared! indicators now flashing on locking and steering wheel lock is working! first time in almost two weeks it is all working ok. Too scared to plug in the IIDtool to see if it is communicating with all ECUs ok though - I'll do it tomorrow.
I will still take it in on Monday and have the wiring looked at but I suppose it could have been water ingress in the electrics on the passenger side either behind the battery or under it???
Post #279510 6th Sep 2014 10:01pm
Get the garage to check for water damage to the headlight levelling ECU, it's located at low level on the passenger side outer side panel near the floor. Wink Thumbs Up
Post #279511 6th Sep 2014 10:10pm
gav
That sounds like the perfect culprit as it was a suspect all along! thanks
Post #279513 6th Sep 2014 10:14pm
gav
Update:
After a long and expensive process. A new LCM and my problems are solved for now
Post #284105 2nd Oct 2014 6:00pm
Dijit
Scotland 2007 Range Rover Vogue TDV8 Java Black
Delighted to hear your sorted. Two questions, how long since the new LCM was fitted and can I please have an idea of cost of the module?
Thanks Rehab is for quitters!!!
RR 2007 3.6 TDV8 Java Black *
RR 2007 3.6 TDV8 Zermatt silver *
RR 2000 P38 4.6 Met red *
Mercedes 300TE 4-Matic *
Jaguar 420 (1969) *
Nissan 300Z
Citroen XM 2.5TD X 6
Bentley Continental R
Hydrocon Highlander
Hydrocon Hamilton
Hydrocon Huntly
Am told the ones with a * are to be offered for sale! 😳
Departed
LR 1992 110 2.5TD
RR 2000 Holland & Holland 4.6 LPG
RR 4.2 Supercharged with LPG, Vogue SE 2007 Buckingham Blue
RR 2002 4.4 V8 Zambesi Silver
Post #284138 2nd Oct 2014 8:26pm
gav
Fitted today. Only done 30 miles so far. Cost of £281 plus vat for the unit and about £180 labour including investigations.
Post #284141 2nd Oct 2014 8:40pm
Dijit
Thanks Gav. Can you please report back with an update in a few weeks?
I've just thought I've cracked similar problems then all too often after a wait of a fortnight it screams 'fooled you'!
Thanks. Rehab is for quitters!!!
Jaguar 420 (1969) *
Nissan 300Z
Hydrocon Highlander
Hydrocon Hamilton
Hydrocon Huntly
Departed
LR 1992 110 2.5TD
Post #284152 2nd Oct 2014 9:11pm
gav
Update after a few months - no further problems *touch wood*
Post #321472 6th Apr 2015 7:54pm
