![]() | Home > Maintenance & Mods (L322) > More Whine ?! AC Problem |
| allycraven Member Since: 28 Mar 2011 Location: North Craigo, Angus Posts: 440
Its the compressor, had the same on my old one, initially thought it was viscous fan as it was rev related but went away with AC off...had it done under warranty so no idea of cost unfortunately,,. '08 Audi S6 Avant 5.2 V10 with Milltek non-resonated. Vrrrrrrmmmmmph
| Jumpy Member Since: 23 Aug 2014 Location: Surrey Posts: 14
Thanks for the advice -makes sense to be the compressor.
| axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964
The compressor will whine when the gas gets low , compressors aren't that expensive but a re-gas is even cheeper but if you can get a new compressor out of the warrantee that might be better and possibly cure the micro leak ( if you have one ) 2008 MY Supercharged
Cheers axle - Sounds like I might as well try a re-gas first. £50 is better than a potential £500 !!!
| Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2287
From memory they have to pressure test the system as part of the regas so if there is a leak it will show up
| Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3276
Unfortunately not all regassers check for a leak. Best to specify that a leak check should be done. John
THanks for the help / advice everyone.
| Cappo Member Since: 19 Sep 2011 Location: Kent Posts: 537
Mine whines as well, I assumed it was bearings, haven't done anything about changing it so far. I could try a gas-up and see I guess.
| Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700
Mine has a small leak, always whines when low, stops when regassed. |
| All times are GMT |
