Home > Maintenance & Mods (L322) > a couple of small job's
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Just checking oil etc and noticed the small rad/cooler by the fuel filter I presume fuel cooler. Bits of hay, birds feather and all sorts sticking out of the side, so undid it and wow there's all sorts of stuff in there. Gave it a good clean and blow out put back together. Then I tackled the bonnet release catch as it seemed a little stiff, on the drivers side under the bonnet there's a join in the cable prise apart and you can put some oil or lubricant in their put back together and the jobs a goodun. Just thought I'd share it as I haven't seen them covered before.
greg.
Post #280072 9th Sep 2014 8:55pm
iphs
England 2003 Range Rover Vogue Td6 Buckingham Blue
Any info on any subject big or small is very welcome gregdav.
Thank you Thumbs Up
Post #280074 9th Sep 2014 8:59pm
Both jobs well mentioned on the forum and should be included as part of the annual service
Post #280111 10th Sep 2014 7:40am
While you are at it you might like to look at the bonnet catches themselves on the underside of the slam panel.
They corrode. Clean them up and cover in grease for protection.
Post #280113 10th Sep 2014 7:43am
best to do these little jobs whilst its still comfortably warm, you dont want to do these in the winter..... ... - .- -.
Post #280114 10th Sep 2014 7:48am
gregdav
Cheers lads will be onto them as soon as time permits Thumbs Up
Post #280118 10th Sep 2014 8:16am
Discotigger
The little rad/cooler is the gearbox oil cooler, I believe. It always gets filled with leaves, etc., I regularly clean mine out. It's a bit faffly getting the duct away from the cooler, but well worth cleaning out to help prevent the gearbox oil from overheating!
Good shout Gregdav!! Thumbs Up
Post #280162 10th Sep 2014 12:45pm
^ The cooler next to the fuel filter is the fuel cooler...
Post #280191 10th Sep 2014 4:04pm
Discotigger
DOH!!
Having a blonde day today!! Embarassed Embarassed
47p2...thanks for putting me straight Thumbs Up Bow down
Post #280221 10th Sep 2014 6:43pm
