![]() | Home > Technical (L322) > Could a weak battery be the cause of this error code? |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6380 ![]() ![]() |
OK,
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
Refraining from stating the obvious, so I'll state another 'obvious' reply of why not change the battery first and see what happens?
I already have the new replacement in the garage, just waiting for a clear few hours to do it, like to take my time on these things and do a proper job, not rushed. Will be using the Wiki. |
and the new battery is sitting at 12.7 V cold with no charge, so I know mine is below par, and you're right, I wasn't going to leave it till the winter cold snaps to see what happens Discovery 4 HSE
Havank Member Since: 05 Apr 2007 Location: Woking - Surrey Posts: 193 ![]() ![]() ![]() |
A couple of hours to change the battery |
Hi Adam, I agree with Bellini, have another look once you changed the battery |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
Agreed battery first then read the faults ooops but you may need a reader to do that |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1902 ![]() ![]() ![]() |
Battery first thing to change, you know FF's like them, I would charge up your spare new battery before fitting though to give it a full charge |
