Home > Technical (L322) > Head light levelling |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3955 |
Chances are no headlight leveling ecu is fitted to your car according to RAVE as follows.
10th Sep 2014 3:59pm |
Liszton3 Member Since: 27 Feb 2012 Location: UK Posts: 2 |
Thank you!
10th Sep 2014 4:36pm |
Might be worth reading this as well before you go back. From the MOT inspection manual.
10th Sep 2014 4:40pm |
gav Member Since: 03 Jan 2014 Location: Hertfordshire Posts: 37 |
Somewhat related.... My levelling unit got wet and corroded and killed the k-bus. My Indy has replaced it with a used one from a td6 and can't reprogram it to petrol with his auto logic system.
10th Sep 2014 4:41pm |
AFAIK the mileage is logged in three different ECUs and if you replace any of them, the black dot will appear on your odometer to indicate a discrepancy between the 3 ECUs in mileage. The systems should still work since ECUs can fail and need to be replaced without "stopping the entire vehicle from working". Hope that helps.
10th Sep 2014 4:49pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Am I missing something here ? Unless your car has adaptive headlights there is no levelling unit to fail, the suspension levelling fulfils that function and you shouldn't have failed the MOT in the first place . 2008 MY Supercharged
11th Sep 2014 2:34am |
Plus one for Axle MY 2010 5.0 SC Galway green and sand interior!!
11th Sep 2014 9:00am |
On the earlier cars, in addition to the air suspension self leveling, there was a self leveling system on each xenon headlight which operated thro a small motors and screw-drives controlled by an ecu. This leveling system operated continuously when the car was driven, small adjustments being made as the car drove along.
11th Sep 2014 9:32am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16188 |
I totally agree... In 2004 the system was binned and a system that worked was not introduced until 2005/06 on the facelift |
11th Sep 2014 9:50am |
Thanks Craig.
12th Sep 2014 4:25pm |
