![]() | Home > Technical (L322) > Another Problem! |
idrawcad Member Since: 13 Jun 2014 Location: Sunny Bournemouth Posts: 144 ![]() ![]() ![]() |
Came home tonight and parked up as normal. Went out to car about 30mins later, inside rear of cabin I could smell anticeptic/hot electrics smell. went back indoors. Now alarm keeps sounding every 20min and all I get on turning the key is a click. Help any ideas please before I start shelling out loads.
So sounds electrical. Check fuses? Check for faults with IIDTool etc. Check main battery connections. Disconnecting battery won't stop the alarm as on separate supply! Check bonnet alarm button OK. Check all doors and windows shut properly. Try locking without interior protection (wifes Audi gets upset if you leave luggage and coats inside, or it spots a beetle/moth on the move). .
Thanks Joe
The smell was strongest in the back seat area. Just been out, now nothing is working. not even the key fob. The car is now completely dead, but it wasn't so the battery must have drained, so I am thinking something has shorted out.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
Main cable to rear from battery ok? There is nothing that can't be fixed with a hammer😜😜
Yes that what I was thinking, the smell is definitely in the back of the car. Is the main cable easy to inspect/find? My Motto: If you are going to have one, have a BIG one! |
Disconnect both +be battery and rear end terminal and then test for continuity between the cable and body, should be absolutely none at all! There is nothing that can't be fixed with a hammer😜😜
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35831 ![]() ![]() |
have a read of this thread,
Thanks Stan,
Speaking to Bournemouth LR and describing the smell (TCP) they suspect alternator failure. Car is being collected and delivered to them on Monday. My Motto: If you are going to have one, have a BIG one! |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
i would mention the FSR change, hope its just that that has fried! thats either in behind console or under console cubby box. there are two i think. |
seems a coincidence john.. ... - .- -.
Just worried if I mention it, it may void the warranty. My Motto: If you are going to have one, have a BIG one! |
Car goes in tomorrow, noticed today a puddle of something under the car, its not oil or petrol. My Motto: If you are going to have one, have a BIG one! |
