![]() | Home > Technical (L322) > TDV8 Lumpy Idle White Smoke |
destructimo Member Since: 24 Apr 2013 Location: Kent Posts: 76 ![]() ![]() ![]() |
Hi Mavester,
MikeC295 Member Since: 24 May 2013 Location: Durham, UK Posts: 32 ![]() ![]() |
I'm getting exactly the same thing with mine. Did you ever find the cause of this? |
mavester Member Since: 16 Oct 2013 Location: United Kingdom Posts: 22 ![]() ![]() ![]() |
I'm afraid not. I haven't had the time to book it in and get it sorted out.
Yeah I definitely find it's much better after a long run even the next day. I also found that it runs better on supermarket fuel...
Same here on the smell of diesel.
Do you know if it's possible to blank the EGR valve off if that's the problem rather than replacing. I have heard of people mapping them out which could be worth considering if you're in it for £180 anyway plus labour for a new EGR it might be around the same money to remap it.
I don't think blanking the EGR is an easy option on the TDV8. I've seen a company offering a software blanking solution (i.e. permanently shutting them) but I don't know how effective this is.
Right then, it seems to be sorted out.
Has it started alright the last few mornings? Out of interest how much did it cost to get sorted? |
Yes, it's been absolutely fine. No white smoke, no lumpiness, no juddering at idle. It's definitely running a lot better now |
