Home > Technical (L322) > Reverse camera fuse?
stuboy00
Scotland 2006 Range Rover Vogue SE Td6 Java Black
Does anybody know if there is a fuse for the reverse camera I've fitted another new one and I'm just getting a black screen now? F**K IT you only live once
Post #280571 12th Sep 2014 3:12pm
normally a battery disconnection helps, details in the wiki.. ... - .- -.
Post #280573 12th Sep 2014 3:34pm
stuboy00
Cheers Stan will give it a try Thumbs Up fingers crossed cause there's a guy coming to buy it tomorrow Big Cry F**K IT you only live once
Post #280576 12th Sep 2014 3:38pm
stuboy00
Tried disconnecting the battery still no signal? Any other ideas? F**K IT you only live once
Post #280647 12th Sep 2014 8:48pm
i suppose you could fit the old camera and see if you get a picture, this could indicate that the new one might be faulty or you have connected it up incorrectly.. ... - .- -.
Post #280650 12th Sep 2014 9:10pm
stuboy00
Yep I could do that Stan, if the old one worked Shocked Laughing Thumbs Up F**K IT you only live once
Post #280658 12th Sep 2014 9:55pm
stuboy00
Just hooked up the IID tool and it's saying the reverse camera is undefined??? Any ideas what that means? Maybe a duff camera F**K IT you only live once
Post #280693 13th Sep 2014 8:04am
RP123
Scotland 2006 Range Rover HSE Td6 Bonatti Grey
Had this when mine went blank - the fuse for the camera is in position 12 ( 5A) is in the back - I just looked at all the 5a fuses till i found one that was burnt out - replaced it and it worked - no longer undefined!!
Hope it helps
RP
Post #280694 13th Sep 2014 8:13am
stuboy00
Brilliant RP Bow down you are the man Thumbs Up probably could have saved myself the cost of a camera but hey ho F**K IT you only live once
Post #280705 13th Sep 2014 9:20am
Check both camera's work before the buyer turns up, then if you have two working camera's sell one to recoup some of the losses Thumbs Up
Post #280720 13th Sep 2014 11:41am
