|  | Home > Technical (L322) > Remote locking drivers door L322 |
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782      | The drivers door should go as well so it is more likely to be something internal in the door or a wiring/connector issue.
|  13th Sep 2014 4:17pm |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002      | I have had both rear door latches replaced because of this issue.
|  13th Sep 2014 4:24pm |
| zoso Member Since: 20 Aug 2014 Location: Ayrshire Posts: 79      | Thanks for the replies gents.
|  13th Sep 2014 4:38pm |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002      | You are making me think now.....
|  13th Sep 2014 4:51pm |
| GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836      | Zoso, is it just the locking which is not working or are some of the other controls also broken? (eg one touch windows, mirror adjustment)
|  13th Sep 2014 8:17pm |
| zoso Member Since: 20 Aug 2014 Location: Ayrshire Posts: 79      | GraemeC.........everything works except the drivers door central locking so it's sounds the same issue as you and Cappo had. I assume the "big connector" is the one on the youtube guide he had to use a screw driver to release !!
|  13th Sep 2014 8:45pm |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | Im afraid it sounds like the latch assembly is goosed sir... Think yourself lucky its not decided to pack up in the deadlocked position otherwise the door would simply not open! Fancy cutting to get it open then  | ||
|  13th Sep 2014 9:49pm |
| Posting Rules
 Then you would be in a worse position than you are now sir
