![]() | Home > Technical (L322) > Brake Pad Warning, HOW DO YOU TURN IT OFF?????????? |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3275 ![]() ![]() ![]() |
Just taken the old sensor cable apart. There are two fine insulated wires running inside the braiding to the sensor. My belief is that the boss on the sensor, which goes to the same side as the friction material, breaks off when it reaches the wear limit and so creates an open circuit giving the fault. John 2008 Stornoway Grey 3.6 Tdv8 Vogue - SOLD 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT-Sold |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 419 ![]() ![]() |
Yes that's how they work. Just a loop of wire that wears through and goes open circuit. If there is a break anywhere else in the system it will give a warning, hence it fails safe. Single wire systems that earth/short won't fail safe so are not a great design, I don't know any modern cars that use it, think my old Renault 5 from the 80's did.
Boydonegood Member Since: 12 May 2014 Location: Essex Posts: 445 ![]() ![]() ![]() |
Did we ever get a definitive answer as to how to turn the light off? I've put a new sensor on and light is still on. Have read so many stories.. Goes off in 2 days... Turn on and off 9 times... Roll one trouser leg up and hop etc etc. only changed it this afternoon but is still on as of now.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3668 ![]() ![]() |
Hi there, I just replaced the sensor and the |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Try turning the ignition on wait for the light to go out , about 20 seconds I think. Then switch off should now be reset.
