![]() | Home > Off Topic > Chainsaw question |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
Anyone know much about chainsaw's?
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8616 ![]() ![]() ![]() |
I recon it's either the battery or the air suspension pump, that seems to be the things that go wrong the most |
Ipslore Member Since: 21 Apr 2013 Location: St Helier Posts: 39 ![]() ![]() ![]() |
Were you using Greg Norman's |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1901 ![]() ![]() ![]() |
My petrol strimmer did something like that, switched off and kept running, came down to a broken wire to earth from the switch. I would check the wiring first, not much to go wrong with a 2 stroke engine! If it dont work.......burn it!
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
as above re. running on, the kill switch, is usually an earthing switch to the ignition wire. switching off, earths the wire, if its has shaken itself to a disconnection, it wont earth and it wont stall. I had this on a chainsaw I had, it then started to run faster and faster, I put it down, and walked away, I eventually threw logs at it till I 'killed it'
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1824 ![]() ![]() |
While I imagine it would be a bit hairy if it happened, I have a hilarious image panning out in my mind ![]() |
Thanks guys
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
^ What about using a generator with it? If I am away from home I put the genny in the boot and take that for a power source.
I seem to remember on my old one, there was also a little lever that stopped the fuel flowing (it basically clamped down the plastic fuel hose).
I am too lazy to drag my generator out of the garage, it weighs a 'ton' (well proably 50kg).
AMD Member Since: 16 Jul 2010 Location: The South Posts: 811 ![]() ![]() |
I'm moving house soon which has about half an acre. Last week I bought a new John Deere X300 tractor mower ( too big but had to be done!) the next on my list is a collection of 2 stroke petrol machines; strimmer, blower, hedge trimmer, chainsaw etc.
Chainsaw fixed, a mass of sawdust in the switch preventing it from working properly. Chain brake is knackered so need to get that fixed and the idle speed seems high now, maybe a service might be worth it.
