![]() | Home > Technical (L322) > Newbie on here with a gearbox issue |
What tyres do you have on them? |
Richards7 Member Since: 15 Sep 2014 Location: Cumbria Posts: 8 ![]() ![]() ![]() |
on the overfinch ones it has 3 toyo proxes 285/35/22 ( I think thats the size as I'm not near the car right now). the fourth is a same size tyre of onknown make, possibly chinese as it was bought in a rush following a puncture. Another thing confusing me is that I have in the past popped on one of the 19 inch originals on in lieu of a spare |
I would be very very surprised that the wheels would have anything to do with the gearbox issues even though it goes away when you are rolling on 19 inchers. I wonder if it makes a difference if the CCF file is updated with the correct wheels !! MY 2010 5.0 SC Galway green and sand interior!!
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1014 ![]() ![]() |
The transmission controller has a ‘curve recognition mode’ which is designed to inhibit upshifts while the vehicle is cornering (for stability) and it kicks in if there’s a speed difference detected of more than 1 km/h between the front wheels. If you have the odd tyre on the front it might be worth swapping it to the rear?
Hmm... Yes the odd tyre although the same size was on the front. I will try to sort this weekend and let you know |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2283 ![]() ![]() ![]() |
Brilliant bit of info Ta for that |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7966 ![]() ![]() ![]() |
Is that on all model years or just the later ones ?
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 ![]() ![]() |
If you want to look after your transmission never run with different tyres and / or large differences of tread on the same axle and if you can help it try and keep it all "same" on all four corners.
