![]() | Home > Maintenance & Mods (L322) > Reversing Camera guidelines |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3927 ![]() ![]() ![]() |
I've just got a 2009 ( MY2010) car which doesn't have surround cameras but I thought that it should display lines on the image when reverse is selected, I do get a rear view but no lines.
It's probably that issue then, is there a fix? Geoff |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Yep............. Replace it sir |
Groan |
If your good with a ruler Yellow felt tip pen might work |
Hi Conor,
Has anyone taken this camera to bits, I have to think its somewhere in the electronics as the screen shows a very clear picture (albeit reversed and sans yellow lines) - Has anyone had a go at fixing or should I just get my hand in my pocket as Craig suggests |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
i suspect your rear view camera might be an early model that didnt have lines... ... - .- -.
Thanks Stan;
any cameras on ebay geoff?
Stan,
So did you check your picture Geoff? Is it reversed? |
Yep it sure is or si erus ti peY
