![]() | Home > Maintenance & Mods (L322) > Reverse lamp upgrade bulbs? |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000
I've had no issues with the amazon ones, but the link says they are currently unavailable, so the choice may be simpler now.....
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
Mine are fine and have had thus far no negative effects |
| pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218
Thank you Craig |
| paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422
Following A11EXU's example...fitted a set of LED's inside the reverse light cluster...30 minutes work and easily put back to standard if required.
| Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204
any warning lights on dash ? are the led strips canbus or normal ? as ive got similar to these, will they work or give warning issues?
Scottyav...No warnings for the ones I purchased....I got 2 sets of these (2 units side by side in each cluster)>>
| Silversurfer13 Member Since: 17 May 2014 Location: London Posts: 83
I'm loving your work Paul....
SS...Yes, thats a great idea..wish I had done that |
Appreciate that Paul
Difficult to say...i'm a "more is better" man myself GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Heated the light units over the cooker flame and the lens prised away easily tbh, stuck two pads in each lamp re sealed the lens back with a good crystal silicone pulled wires out of the back and they come with all attachments to put in any holder so no need to butcher anything, put reverse in looked bright so couldn't wait till later when I came back so took a few pics of the brightness now and looks fine to me the bottom ones like daylight and it's really dark here at 10-45pm lol 😎😎😎
That looks impressive.
| J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541
Now they do look bright |
Nice job....Can you see the LEDs thru the lens when off Scottyav? or did you find a fix to that?
