![]() | Home > Maintenance & Mods (L322) > Help!..Trolley jack jacking points? |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
Cant they be locked in the open position to give access to the jacking points??..cr |
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541 ![]() ![]() ![]() |
Agreed Paul,
Read here matey>>
Thanks Paul, ....again |
Theres a diagram half way down
Haha, I think the threat of death is a bit harsh because I didn't use the search option mate, but thanks anyway |
Ok, I've locked out the 'Deplorable' steps but the standard jack will still not fit in its correct cup
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Never had a problem jacking up under the lower wishbone arm at the rear, spread the load with a suitable wood block. This OK if just changing a wheel, as you aren't "going under" and you can always put a safety stand under your jacking point if needs be. .
Thanks Joe,
