Home > Maintenance & Mods (L322) > L322 Headlight control unit- where to buy?
Cryptic
2002 Range Rover Vogue 4.4 V8 Java Black
Hi,
got a dipped main beam that was only lighting if you clicked it on and off a couple of times - and now won't fire at all.
I believe I'll need a control unit \ ballast. Can you guys point me in direction of suppliers please (UK)?
Thanks
Post #282086 21st Sep 2014 10:41am
My advise would be to buy a second hand headlamp (£50 of flabby) as it could be A, bulb B, ECU (on rear of headlamp) or C, the ballast...
You could then strip your lamp down (which is quite straight forward) and test the parts as you fit them sir Thumbs Up
Post #282092 21st Sep 2014 11:04am
Cryptic
Can't see any full units at that kind of price. Confused
In terms of spare bits on fleabay, only seem to be the control units off the back of the headlight. I take it the ballast is separate?
Want to see what prices new parts are - am leery of buying used electrical bits from ebay - most are no returns and could be just as goosed as the ones I've got Wink
Post #282096 21st Sep 2014 11:14am
You cannot buy the Ballast from JLR... The ECU is around £250 from memory and the bulb £160...
Post #282100 21st Sep 2014 11:17am
Cryptic
Thanks. So pretty damned pricey then. Shocked
I'll swap items from working side one at a time to identify the fault.
If it is the ballast, and you can't get it from JLR, is there anywhere else?
Post #282110 21st Sep 2014 12:27pm
We may have some but i would need to have a dig sir... Thumbs Up
Post #282111 21st Sep 2014 12:42pm
Cryptic
Swapping bits round confirms I need one of these
Post #282133 21st Sep 2014 3:19pm
