![]() | Home > Maintenance & Mods (L322) > wise to replace Torque converter only? |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502 ![]() ![]() ![]() |
have you tried going straight to Ashcorfts and asking them for prices? |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3259 ![]() ![]() ![]() |
Yes seen those. At £150 for a TC, i could get my local indie to fit, hence the 5 hr? Q and at £40/hr, it is a cost effective option.
try ringing Dave and asking him as to benefits or if its worth while, i am note sure how much wear your would have and if it would be justified.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7993 ![]() ![]() ![]() |
I am sure I saw on here somewhere about an uprated torque converter, but I can't seem to find the thread....... 2011 Range Rover Vogue SE 4.4 TDV8
RCusden Member Since: 12 May 2012 Location: NarberthPembrokeshire Posts: 186 ![]() ![]() |
/\ was it river stock that got an uprated one and the gearbox ecotune ecu for his. I liked the sound of all that but then read one of rrphil's posts about poss causing issues with the tc locking up to soon.
Ah yes, thanks. Turns out its actually Riverstick
it was Riverstick but it was for a Doozle.
Ah, sorry.
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1031 ![]() ![]() |
There’re only a couple of ‘standard’ faults with the 5HP24 in the L322. One is the torque converter lock-up clutch (which you’re seeking to address) and the other is the axial bearing failure between the B-clutch hub & the C-clutch drum. Because the likelihood of failure of the latter will depend on how much time your vehicle has spent in 1st, 2nd & 3rd gears, and at what speed & load, it’s very difficult to predict a mileage at which this might occur (if, indeed, ever). If the vehicle has spent much of its life in hilly areas towing trailers then clearly it’s going to happen sooner than if the majority of its duty cycle consists of travelling up and down the motorway.
Phil, once again you are the Oracle!! I am determined to drop off a case of beer next time I am passing your gaff!
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 ![]() ![]() ![]() |
For what it's worth, I sent mine to JPat. They collected it on a Friday and I had it back the following Tuesday.
Thx vaz. |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 419 ![]() ![]() |
I was quoted £180+VAT from Sussex Auto Parts earlier in the year for recon.
That's great news WeeJ. THx. |
