Home > Maintenance & Mods (L322) > Are these mirror lights
jakebullet64
United Kingdom 2003 Range Rover Vogue 4.4 V8 Santorini Black
morning chaps,
found these under the mirror, but i've never seen them light up.
just want to make sure they're lights before I start taking things apart.
cheers
jake
[/img]
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2003 Range Rover Vogue 4.4 on Gas
1961 88" 2.25 diesel - George
Gone - 1997 3.9 V8i Discovery - Burt
Post #283034 27th Sep 2014 8:00am
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
yes and light up when unlocking the FF. Thumbs Up If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #283038 27th Sep 2014 8:26am
jakebullet64
hi WD, thanks for replying.
they've never lit up, so I presume check fuse, bulb then take it from there I suppose?
cheers
jake 2003 Range Rover Vogue 4.4 on Gas
Post #283042 27th Sep 2014 9:05am
Welshdragon
all you can do at the moment Very Happy If it dont work.......burn it!
Post #283048 27th Sep 2014 9:49am
Jake, yes check all the obvious BUT, they don't work in conjunction with the interior lights per say... They shold come on when you unlock the car but, only for a couple of times then the BCU switches them off (to protect the battery Thumbs Up
They are also current sensitive so from memory if you fit LED bulbs (they don't like it) or if one bulb blows (they don't like that either)
The point I'm trying to get across is, once you have stripped the mirrors down to inspect the bulbs, they probably will have timed out... The interior lights will remain working and you may continue looking for a fault that does not exist sir Thumbs Up
Post #283049 27th Sep 2014 9:52am
