![]() | Home > Technical (L322) > obd2 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35832 ![]() ![]() |
am i correct in assuming that a basic obd2 interface cable connected to my laptop will only read and clear engine faults and light failure faults and if i wanted to clear an airbag fault or activate 'nav on the go' then i would have to pay the bloke in cyprus loads of money for a faultmate.. ... - .- -.
Correct.
what about light faults dan, ie replacing a halogen bulb with a led, can i clear that fault on the dash readout.would it be a usb scanner/interface ... - .- -.
That would come under LCM (light control module) mods I turned off the bulb check for the side lights as I put LED's in there. Dan ![]() |
so i need a ibus interface then, so as far as i know with mine being a touch screen and having a MOST system is there a an interface cable for this.. ... - .- -.
Is there any iBus stuff? Does yours still have a LCM?
dunno re the ibus stuff, i know mine was in the cross over period from bmw to ford so maybe some bits are..bloody confusing this..thanks dan. |
scarey, there is a cheaper version of the unit you want, it will read and clear loads of stuff,from engine to air bags
thanks dave, i looked at the faultmate msv2 but at around £1k its way to much for the average diy'er..i'll have a look at that one but it would be nice to be able to buy a cable for £20 and get some software to do these things.. ... - .- -.
if we could only get hold of THE proper software, now that would be good.. |
Yeah but even THE proper software won't do what a faultmate can |
but its all down to cost as well... ... - .- -.
Compared to the cost of dealer diagnosis on faults and also the cost of adding options to the car, some of which even the dealers can't do, (D3 cruise control for example) I don't think it's unreasonable. A fair chunk of money maybe but even at about £1k, if it saves you £2k over the years then it was a good investment, yes?
GKP Member Since: 01 Aug 2009 Location: Hants Posts: 75 ![]() ![]() ![]() |
Yep, the MSV2 Nano was one of the first tools I bought for my current car and replaced the unit I had for my old P38. Sure it's an expensive initial outlay, but it means I can tackle any job on the car without issue.
