![]() | Home > Technical (L322) > Brake shudder help L322 |
le25dse Member Since: 15 Jan 2012 Location: Oslo Posts: 78 ![]() ![]() ![]() |
It may very well be the lose brake shield. They rust around the bolts and will make a lot of noise when they come lose. You can fix it by unscrewing the fastening bolts and add a larger shim to hold it in Place. Replacing the brake Shield is a huge job, as the hub needs to come off. ----------
MariusRR Member Since: 19 Mar 2013 Location: Oslo Posts: 105 ![]() ![]() ![]() |
Hi.
