Home > Maintenance & Mods (L322) > Gearbox flush
Page 3 of 11 <123 4 ... 91011>
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
i think i will just get the sump/filter conversion and drop the oil for a partial change.
where is the filler on this box? Cheers
James
Post #283506 29th Sep 2014 10:46am
salb
United Kingdom 2007 Range Rover Vogue SE Supercharged Santorini Black
landrover specialists.
Here goes guys i ring a land rover specialist local one, i ask him regarding an inspection 1
service, he said he will call me back.
Then i ask him about a gearbox oil change and a megaflush, and a software upgrade.
Well the answer shocked me.
"Yes we do oil changes and also add an additive, but the software upgrade on a gearbox never heard of them"
So i proceed to tell him about the forum and that i own a IID TOOL, his answer.
" I DONT TAKE ANY NOTICE OF FORUMS, IF THEY KNEW WHAT THEY WERE DOING THEY WOULD BE MECHANICS"
then i entered into a heated debate with him putting a point of view across to the wealth of information and technical know how that most of you possess, fell on deaf ears I'm afraid.
sal RANGE ROVER OVERFINCHED 4.2 S/C
FRONT BUMPER O/F
REAR BUMPER. O/F
BOOT SPOILER O/F
22" ALLOYS. O/F
STAINLESS STEEL EXHAUST O/F
CARBON FIBRE WING MIRRORS & A PILLARS & CENTRE CONSOLE
Post #283510 29th Sep 2014 10:58am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
@salb name and shame! Sounds like someone is a little bent out of shape at the idea of an informed customer who pulled them on their lack of knowledge.. Never heard of updating a transmission ECU?!
If you don't want to name on the forum, PM me, I'm in Cheshire and want to make sure I never accidentally call them!!
I'm looking for a megaflush myself on my SC but don't fancy driving to Kent. (as lovely as it is there)
Steve Thumbs Up
Post #283524 29th Sep 2014 12:10pm
salb
BARTRAM LANDROVERS IN ACCRINGTON........................
I am so surprised as this company was recommended to me.
Now I'm stuck as i need to do an INSPECTION 1 SERVICE AND OIL AND MEGAFLUSH.
the thing is in 2.5 yrs i have only done 14,000 miles and look after it as best as i can and i need to know when
i hand it over i don't get screwed over.
So anyone know of anyone in lancashire please.
thanks
FRONT BUMPER O/F
REAR BUMPER. O/F
BOOT SPOILER O/F
22" ALLOYS. O/F
Post #283552 29th Sep 2014 2:00pm
salb
gearbox
As RRPHIL is from blackburn would he know where to get the oil service and megaflush.
FRONT BUMPER O/F
REAR BUMPER. O/F
BOOT SPOILER O/F
22" ALLOYS. O/F
Post #283559 29th Sep 2014 2:21pm
salb
anyone heard of 4TECH IN WISBEACH, do megaflush for range rover, 95% flush.
FRONT BUMPER O/F
REAR BUMPER. O/F
BOOT SPOILER O/F
22" ALLOYS. O/F
Post #283581 29th Sep 2014 3:51pm
Mikey
Re: landrover specialists.
How does he know we are not Whistle Thumbs Up
Post #283592 29th Sep 2014 5:05pm
Harris
United Kingdom 2006 Range Rover Vogue TDV8 Zermatt Silver
Just had a flush and oil change done by IAWA in Wellingbourough at 99k when they took the sump off they said the oil was like treacle. The gear changes cold are now much smoother
Post #295823 29th Nov 2014 9:08am
Chauch
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Glad it worked out - IAWA made a massive difference to the way mine shifts as well and it is getting better and better a few thousand miles on.... 4.2 Supercharged Vogue SE
Post #295825 29th Nov 2014 9:17am
Ok, where to start...
I have looked into "mobile flushes" and want to share my findings...
I was alarmed to hear customers & forum members talking about "mega flushing the gearbox" so, when i checked 8 out of 8 companies whilst doing there "mega flush" DO NOT change the filter! ABSOLUTE MADNESS!!!! Or run through the proper routine to re-fill the system. Therefore leaving the system unto 1ltr short of fluid! (although most were 1/2ltr short)
two of these companies were premises based too!
I have been looking after an ageing D3 TDV6 for the past 4 years for a good mate... Purchased it with 190k slipping TC (rev counter bouncing 1000 revs on motorway) and changed his oil using the double flush method and added Dr Trannies and the box has been perfect for 4 years & 40k... Just done a second similar change a few weeks ago 40k on and a very happy mate... Thumbs Up
I only do oil changes at work and double if they are particularly bad!
Don't forget, unless you have got the fluid changed before 40k then the damage has already begun! imho
Post #295840 29th Nov 2014 10:24am
miggit
I've got to agree with Craig on that one, if you wait to do the oil change anywhere near the 75k recommendation, your screwed, the box will be FUBAR'd just wont have failed yet.
The garage that rebuilt my box has recommended that I change the oil and filter every 12k, because of the heavy towing that I do, however he does not believe in power flushing. The biggest cause of transmission failure is the filter, because it doesn't very well. Because the box is sealed for life, they have to put a coarser filter in, to stop it blocking at 40k, this then causes the finer particles to be recirculated, thus doing more damage and getting finer all the time.
The best way to do this, is to change the filter before it gets to the semi blocked stage and starts to pull the muck through, then by changing only the oil in the sump and the filter, you will have removed any particles before they get the chance to be recirculated. Yes you have to do it more often, but you will save on the power flush cost, what you gain in one hand the other takes away Sad
I personally recon that if you were to change the oil and filter every 24k, as per old fashioned boxes, you should be alright. Provided that you don't do heavy towing all the time. If you spend 50% of your driving coupled to a trailer over 2 tons, like me (normally 3.2 tons), then you've got to be looking at annual oil changes.
And before I'm chastised for not recommending power flushing, I've got ask how many of you power flush the engine? So why should a gearbox be different? Whistle Yesterday I couldn't spell Engineer... Today I are one!
Post #295860 29th Nov 2014 12:59pm
Mikey
The gearbox is power flushed, as a drain and refill only gets 4-4.5 litres of oil out of the gearbox, which has a capacity of 11 litres. A double flush still only replaces 50%, due to the new oil mixing with the old...
You wouldn't drain 3 litres out of your engine when changing it,would you Whistle
Post #295874 29th Nov 2014 1:46pm
miggit
No I would not, but I do not power flush it either, I just change whats in the sump and replace the filter. Which is all I'm going to be doing with the gearbox, but at 12k, nearer to what you'd do with the engine.
Put it another way, would you do 40k on the same engine oil?
Post #295879 29th Nov 2014 1:53pm
miggit
Or to go further in to this, a filter set costs about £39, 20 litres of texaco oil can be had for £70, if you use 5 litres of oil every change, and do it every 24k, for total outlay of £226 you can get 96k out of the box. How much is your power flush going to cost? at 40k or a double flush at 75k?
From where I'm sitting, even at 12K intervals, I'll be saving, and keeping the box going longer. Yesterday I couldn't spell Engineer... Today I are one!
Post #295880 29th Nov 2014 2:02pm
Mikey
We are talking about different gearboxes here Thumbs Up
I wouldn't power flush the 5 speed FM or ZF boxes either Whistle
I was talking about the 6 + 8 speed ZF box. The oil is a whole lot more expensive for that box, than the 5 speed. And the filter is cheaper too.
I am a sponsor on D3 and RRS forums, so mainly flush these cars (though have done a few FFRRs)
The sump is a whole lot more awkward to remove on the D3/RRS. Though having cut open an 80k mile filter, there was nothing wrong with it. No metallic particles at all
You need to flush it BEFORE the damage occurs. ZF recommend between 50-75k for normal driving, more frequent for regular towing Thumbs Up
Post #295929 29th Nov 2014 7:54pm
