Home > Technical (L322) > Airbag light
W88DY M
United Kingdom 2003 Range Rover Vogue Td6 Oslo Blue
Airbag light
Hi all, just a quick one if anyone can help. If my airbag has been removed from the doors and been put back again will the airbag light on the dash need resetting
Post #283991 1st Oct 2014 8:42pm
W88DY M
Anyone Very Happy
Post #283992 1st Oct 2014 8:46pm
i'm shocked that nobody answered you in 4 minutes.. Evil or Very Mad ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #283993 1st Oct 2014 8:50pm
Only if you put the ignition on when the airbag is disconnected. If the keys are out then you should not need the light resetting...
Always best practice to take the battery earth lead off whilst doing any work needing airbag disconnection sir Thumbs Up
Post #283995 1st Oct 2014 8:52pm
W88DY M
Sorry stan Embarassed
Thanks Craig, I've just had some body work done on my ff, I've got it back with the airbag light, htc and air susp lights on
I seen that they removed the airbags, but they are saying it's not down to them to sort it outis there anything I can do?
Post #283997 1st Oct 2014 8:59pm
Have you driven it yet? If not, the HTC & A.S. will go out when the steering sensor is reset Thumbs Up
Airbag light will need to be reset on diagnostics I'm afraid... Thumbs Up
Post #283999 1st Oct 2014 9:02pm
W88DY M
I have Craig, and I've tried lock to lock but still no joy. It's going back in the morning so they can have a look. Also the rear view mirror looks like something has leaked inside ? Censored
Post #284000 1st Oct 2014 9:08pm
Ahhhh now it all makes sense sir... Whistle
They have plugged your drivers door electric window switch panel in INCORRECTLY sir... The forward most "lower suspension" button uses the same plug as the "Electric mirror" switch.
So! They have at best knackered your mirror glasses (very expensive) and hopefully if you swap the switches back over the suspension lights will go out! Rolling Eyes
Post #284003 1st Oct 2014 9:19pm
W88DY M
Craig are you talking about the rear view mirror glass, sorry if I sound stupid
Post #284005 1st Oct 2014 9:24pm
Electrochromatic tinting of three mirrors (one inside & 2 door mirrors) get the wrong signal when the air suspension plug is plugged into it in the drivers door panel... Which is why the fluid has seeped out internally...
Post #284010 1st Oct 2014 9:31pm
W88DY M
Craig I really appreciate that thanks very much I'll let you's know what happens tomorrow
1 more thing will the air bags still work the way they are?
Post #284012 1st Oct 2014 9:36pm
NO sir the Airbags probably will NOT work as is...
My advise would be to invite them to remove the drivers door card whilst you stand over them... Make note of which plugs go into which electrical socket (on the rear of the electric window switch pack) Ill place a large wager on the electric mirror plug has been pulled REALLY tight forward and fitted into the suspension lowering switch socket & visa versa...
If you don't stand over them then they can just lie about the wiring plugs being the wrong way around and you will have NO recourse for the damaged mirror/mirror lenses (at least) maybe even more damage could occur!
Post #284014 1st Oct 2014 9:48pm
W88DY M
Will do thanks very much for all your help
Post #284015 1st Oct 2014 9:52pm
Do let us know how you get on sir Thumbs Up
Post #284017 1st Oct 2014 9:53pm
W88DY M
Will do Thumbs Up
Post #284018 1st Oct 2014 9:55pm
