Home > Technical (L322) > Suspension Fault Max Speed 30mph and HDS INACTIVE warnings |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 |
Impossible to say.......
3rd Oct 2014 12:12am |
tato Member Since: 02 Oct 2014 Location: Buenos Aires Posts: 2 |
Thanks Skot |
3rd Oct 2014 12:18am |
Keep an open mind. Once you know the fault code(s) from diagnostics there is every chance it's a simple, easy fix! 2006 4.2 SC
3rd Oct 2014 12:23am |
mavester Member Since: 16 Oct 2013 Location: United Kingdom Posts: 22 |
Mine did this for a while and then it stopped. Weird.
3rd Oct 2014 11:45am |
rover1 Member Since: 17 Sep 2014 Location: Dumfries Posts: 31 |
I had the exact same problem. I found no fault code.
6th Oct 2014 1:10am |
salb Member Since: 25 Feb 2012 Location: blackburn Posts: 332 |
IID TOOL purchase a must..............
6th Oct 2014 7:29am |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 |
I get this very occasionally if moving off too fast after start up and height at access. Turn off & on again and fault clears. Previous cars:
6th Oct 2014 2:53pm |
aclr8r Member Since: 22 Oct 2013 Location: Norwich, Norfolk Posts: 23 |
Could be the steering angle sensor?
12th Oct 2014 12:39pm |
Could be caused by a faulty ABS sensor in one the rear wheel hubs |
12th Oct 2014 1:11pm |
