Home > Technical (L322) > Front axle balljoint rear most |
Proper PITA to remove. They are held on with Torx bolts of which the heads are easily rounded when trying to remove them, then the driveshaft CV knuckle is in the way limiting access to give the joint a good whack with a hammer. |
3rd Oct 2014 5:59pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1254 |
the hardest part is getting the bolts off. I ended up using Bolt grip remover sockets (google them - irwin tools do a set) and hammering them onto the bolt and then undoing it ( worked very well )
7th Oct 2014 11:30pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
Had a hub assembly off a damaged car this week and 2 hits with a decent hammer and the ball joint fell out Easy peasie with the hub off... Never tried one in situ |
7th Oct 2014 11:44pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1898 |
Thanks guys, it does look a pita to do!
8th Oct 2014 8:49am |
steve9bug Member Since: 25 Aug 2013 Location: sunderland Posts: 356 |
Did mine on the car but might be easier for you to remove the arm you will get better access to it when off. |
8th Oct 2014 9:33am |
Mine were replaced......
8th Oct 2014 10:47pm |
Landed up pressing a wheel bearing into that hub today as putting it back together it just didn't feel perfect! Good job too as when i pressed it out it fell to bits! Not so lucky i guess |
8th Oct 2014 11:10pm |
