Home > Maintenance & Mods (L322) > MICROCAT
MICROCAT
If you are needing to get your hands on the Microcat parts catalogue for finding things, then use this resource
http://www.retroanaconda.com/landrover/2009/12/land-rover-microcat-november-2009/
and follow the howto in order to get it working.
"Geek Alert"... Smile
As a linux user, I have to run Microcat inside an XP virtual machine using VirtualBox. One problem with this is that VirtualBox will quickly reset the date if you change it. If you want to do the same, then to overcome this, you need to add a line to your machine's xml file
There should be a few entries already in the Extradata section. Find this and add the line below, Save out and try again.
<ExtraData>
ExtraDataItem name="VBoxInternal/Devices/VMMDev/0/Config/GetHostTimeDisabled" value="1"
</ExtraData>
NB this forum won't let me post the < /> around the line you need to add, so i took a picture of it too
Post #28386 18th Sep 2010 1:09pm
darrenmax
Belgium 2003 Range Rover Vogue Td6 Giverny Green
i've wanted this for ages but dont have a clue how to do it Embarassed Embarassed Embarassed 2002 td6 vogue, 06 supercharged facelift
Post #28394 18th Sep 2010 3:37pm
Check your pms darrenmax .
Post #28409 18th Sep 2010 5:45pm
stevegt
United Kingdom 2006 Range Rover Autobiography 4.4 V8 Cairns Blue
I have the May 2010 disks with the cracked file to remove the dongle requirement if anybody ants a copy... 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #28427 19th Sep 2010 12:23am
SteveMFr
Site Sponsor
Yes please!! My copy is Oct.06...
I've sent you a PM.
Thank you! Thumbs Up
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #28439 19th Sep 2010 11:01am
stevegt
Ok I have copied the disks into the ISO format and am currently uploading them to a server. I will post a link when it is complete 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #28505 19th Sep 2010 8:14pm
mzplcg
Diamond Geezer Thumbs Up Thumbs Up
Post #28506 19th Sep 2010 8:28pm
stevegt
Here we go
https://files.me.com/stevegt/zftwlp
Any problems let me know 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #28550 20th Sep 2010 9:16am
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
Thank you and may I suggest this smart and free software that solves the date problem without changing the computer's one: http://www.nirsoft.net/utils/run_as_date.html
Post #28587 20th Sep 2010 3:53pm
Can you please confirm this works with Microcat (Nov 2009 or May 2010 versions)? Question .
Post #28615 20th Sep 2010 8:56pm
adara
Yes, tried with both. Make sure immediate mode is ticked and also right click on RunAsDate.exe and choose Run as administrator.
Post #28618 20th Sep 2010 9:35pm
Thanks adara, I'll give it a whirl. Good info Smile .
Post #28621 20th Sep 2010 10:20pm
stevegt
Is there any chance that we can have this thread pinned as a sticky so it stays at the top of the screen? 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #28954 23rd Sep 2010 9:23am
Another link:
10.2010 includes fix
http://www.hotfile.com/list/909148/5f33111
Post #31295 9th Oct 2010 11:22pm
